dwh367
Long story short I was trying to help someone with a problem they had with their scanner (on another platform). They had just received it brand new and couldn't get it to work correctly. After some research I narrowed the problem down to simulcast distortion.
I mentioned to them that the Uniden SDS series would have been a better choice for their particular area. At that point they went off the rails about how they had just spent over $400 on that scanner and that they had gotten ripped off and on and on.
I sent them a link on things to to try in order to get their current scanner to work with their simulcast system. I also sent them a link about SDRs. They wouldn't have any of it. I finally ended having to block them just to get them to shut up.
The moral of the story is if you're new to scanners do some research before you buy your new scanner. If there's something you don't understand then ask questions. Ultimately it's up to you to figure out which scanner will work best for your needs. It's not Uniden's or Whistler's problem if you got the wrong one. You ordered it and they sent it. Their job is done at that point.
