Dodge Ram 1500
Leasure
Ohio
I'm in the process of buying a 2003 Dodge Ram 1500. I'm needing to place the following; Federal Signal PA300, Radio Shack 163 scanner, along with a 3-way cigarette pug that runs my light bar, and front window mount that will be placed for VFF uses. Has anyone made any consuls or have any ideas on placement? The large cup holder and comes down and eats up a lot of space.
Thanks.
KE5TNY
Ok this may sound totally Ghetto..... but I have an 03. I am running ham gear in it currently. I places a piece of mdf under the lining of the center seat and bolted my yaseu 1802 to it then bracketed a radioshack cb to the top of it (same size). that still gave me clearance for the cup holder without having to create the console.I ran 90 degree out of the back of the radios to the antennas I ran the power cords under the flooring (mine is rubber) to the dash. Total cost : 3$ for the brackets. Ill try to get a pic to post later. Im not sure on the siren. But I think the scanner comes with a mounting bracket, it should work.
Magnetsteve
Central Arkansas
I used to have an '04 Ram 1500. If you eliminate the cupholders that gives you plenty of room to play. A small sacrifice I had to make, but it ended up looking great. Wish I had pictures of it. Just giving my two cents
DieselFF918
West Milton, OH
a cig lighter for a lightbar?
WTF?
Could be a mini light bar.
I have a Whelen strobe light bar, and a Federal Signal halogen bar, both are mini bars and ran off of the cig lighter, before I direct wired them, same with a Code 3 420 halogen mini bar, I used to have.
