Does a private repeater have to be licensed through the FCC?
ecps92
Taxachusetts
++1 :cool:
No. Base radios can use repeaters. When a base is transmitting through a repeater, they are usually referred to as "Control Stations"
§95.29 Channels available.
(b) For a mobile station, control station, or fixed station operated in the duplex mode, the following 467 MHz channels may be used only to transmit communications through a repeater station and for remotely controlling a repeater station. The licensee of the GMRS system must select the transmitting channels or channel pairs (see §95.7(a) of this part) for the stations operated in the duplex mode, from the following 467 MHz channels:
467.5500, 467.5750, 467.6000, 467.6250, 467.6500, 467.6750, 467.7000 and 467.7250.
KB7MIB
Peoria, AZ.
The base station class of land station and the control station class of land station aren't (or weren't under the 1988 version of the rules) allowed to communicate with each other. You weren't allowed to communicate base-to-base via simplex, or control-to-control via a repeater (or base-to-control or vice versa via a mix of simplex and repeater assistance).
However, a land station was allowed to be licensed as both a base station and a control station, in order to communicate with mobile station units. When operating simplex, it was a base station. When operating through a repeater, it was a control station. (95.25(a) through (f); 95.55(a) & (b); 95.57(a) & (b); 95.59(a) through(c), <i>from the 1988 version of the rules</i>.)
Oh, and control stations were required, under 95.47(b)(1) & (2) to use a directional antenna with a 15dB front-back ratio, and were required to use the minimum transmitter power necessary to establish and maintain realiable communications, which was determined by a control station power test. Again, this is from the 1988 version of the rules.
I really wish the latest version of the rules had actually been rewritten, and not, as it seems, just been the result of deleting sections of the previous version. It might make it a bit less confusing...
John
WPXJ-598
Peoria, AZ
