Does anyone know anything about this model number?
WPXS472
Heflin, AL
I have been fooling around with some HT1000s and seeing if I can do a little hacking. So, the other day, I was looking at HT1000 RSS with a hex editor and ran across the following model number in the program:H01WCC4AA1AN. I thought that was strange seeing as how there never was a 900 MHz model.
Just for fun, I changed the model number in a 800 MHz codeplug to the above model and when I loaded it into the RSS, all I got was a "Bandsplit doesn't match model" warning. Other than that, it showed to be a 16 channel HT1000. It corrected the bandsplit from 15 to 13 when I saved it. A Google search for it turns up nothing. I don't remember exactly which version of the software I saw this in. I seem to think it was 3.03. Any explanations?
The HT1000/JT1000/Visar Page
The Visar and Jedi's used the same RSS. There is a 900MHz Visar model, at least according to BatLabs.
Probably what you are seeing.
Or….
Could have been a planned model, but nixed before production.
WPXS472
Heflin, AL
I have never seen any mention of 900 MHz HT1000s. Do you know where that information might be located?
The 900 MHz Visar was made in a trunked model only and its RSS is called VisarPP. Besides, the Visar model numbers all start with H05, not H01. It could be a model that was planned, but never made. I also wonder if maybe it could have been a special model made for one customer. You see all kinds of weird stuff that came out of Motorola. I have a Visar with no display and no channel select buttons. None of the RSS I have will read it. The Model tag on the inside of the back is missing. I have never seen any mention of it anywhere. I suspect it was a special trunked model with one system, and only one talk group.
SP models exist.
Since the RF boards can be swapped easily, I guess that they could have put 900MHz rf boards from another Jedi model (MTS?) with an HT1000 control board. SP product, another market, who knows.
If you really want to know, go check over at BatLabs forum. Likely someone will know, or it's already been discussed.
MTS2000des
5B2_BEE00 Czar
Not sure if the HT1000 900MHz supports HearClear, but if the controller has HearClear, it may be an issue if you slapped a V/U RF board and can't disable the HC circuitry as it wasn't used on V/U Jedis (at least not that I am aware of).
It wasn't an SP model by any means, there were some 900MHz conventional customers back in the 1990s. A local EMC here was one of them (later transitioned to an EDACS/PV now TETRA)
