does anyone use an Astro spectra base HHCH set up
mid cities, Texas
I have an astro spectra unit that i am going to set up when i move into my new house. I need to get a HHCH and power supply.
I was told to use a 35amp power supply for a base set up.
Does anyone have any photos or experience using an astro spectra with an HHCH as a base?
uman18
PORT HUENEME,CA
I ran a Hhch in my garage, for use on 2m ham , it would get hot! Only down size is the length of the mic cord . You can use a printer cable (DB25 cable) that is shielded to extend the mic cable if needed. I used a Astro 35 amp power supply with no issues. That's more then enough power.
mid cities, Texas
I was using an astron S11A with the 45 watt unit, but after 25 mins it gets hot and trips from continuous receiving. I changed the fuse, but it still trips. I'm looking into a 35 amp power supply, but their pretty pricey
uman18
PORT HUENEME,CA
Look into a HPN4001 motorola switching power supply. I run one of those on my XTL5000. Also on RX they shouldn't draw much power.
