Does Kenwood Make a Dual Band Part 90 Mobile?
12dbsinad
For a analog only solution with no frills you're better off going with dedicated front mount mobile radio's in the rig. WAY cheaper and will do what you need to do. Even if you had to remote mount all of them it's still way cheaper. Take all that extra money you'd spend on a part 90 dual band radio and put it to other uses to save lives.
wwhitby
Autauga County, Alabama
Pictured are the NX-700 and TK-5820 remote heads neatly mounted and taking up little very little console space.
That's exactly why I just upgraded to a TK-7180 and TK-8180 in my soon to be new truck. The remote mount kits and small heads make for an install taking up very little real estate.
At the risk of sounding like a broken record, OP I would also recommend going with two mobile radios and remote mount kits. You'll find this will fit your needs very well.
RodStrong
West
Not necessarily trying to derail or stray away from Kenwood or the models mentioned, but there are several other analog radios which can be had new for a fraction of the cost of some of the higher tier stuff mentioned in the thread. Just an example, something like an Icom F-5021 or F-6021 can be had for approx $275 each. Not high tier (doesn't sound like that's needed), 45/50 watts (plenty of power for most situations), bulletproof, and the radios are barely bigger than the size of a sandwich.
Again, not trying to steer you away from your original post, but if you're on a tight budget and need good analog radios that don't take up a lot of space, you can do it (installed) for well under a thousand dollars.
On a side note, I have nearly all the models discussed in this thread in service (including the 4 deck VM7000's, APX8500's, etc.), and they are all great and have their place IMO. But it sounds like you need something simple, bulletproof, small, and cheap. Based on that, I'd go for the smaller analog rigs I mentioned or something comparable. Good luck.
