I just underwent a complete hard drive wipe to install Microsoft Windows 10 Home Version 21H1. This gives me a fresh start on life and a very fast running system that had become increasingly sluggish over the years . HDD and registry defrags and other system maintenance actions did not achieve the performance that I have now. Not wanting to copy any corrupted files back onto the HDD, I am reloading the essential programs to keep things running smoothly around here.
Then comes Sentinel Version 2.02.01 and the corresponding serial drivers. As a matter of course, I had previously loaded Microsoft .NET Framework v5.0.6 for another program but when I go to load Sentinel, I get an error dialog that states in part "This setup requires the .NET Framework version 2.0. Please install the .NET Framework and run this setup again."
Does Sentinel absolutely require .NET Framework version 2.0 and nothing higher?
Surely that is not the case. Microsoft .NET Framework version 2.0 is no longer supported by Microsoft. Anyway, I loaded .NET Framework version 2.0.9 and the Sentinel loader is still giving me the same error dialog that states in part "This setup requires the .NET Framework version 2.0. Please install the .NET Framework and run this setup again."
So I wonder what the issue could be? Surely Sentinel is not looking for Version 2.0 exactly. Has anybody tried to install Sentinel version 2.02.01 on a new computer with Windows 10 Home version 21H1 which became available on 18 May 2021 according to this Microsoft Windows Blog posting? While I mainly use ProScan and BuTel Software's ARC536PRO, which by the way are running under Microsoft Windows 10 Home version 21H1 and Microsoft .NET Framework version 5.0.6 just fine, I do use Uniden's Sentinel software every now and then. Of course, there are some things that can only be done with Sentinel software.
Anybody with some things that I might try to alleviate this issue, your comments will be greatly appreciated. Finally, here is a shoutout to @JoeBearcat who might also be able to shed some light on this dilemma.
Thanks everyone for reading! Cheers!
Dave K4EET
Dave K4EET
