Anytone Does this radio pickup more?
Bralmo1
Minnesota
Hello, I bought a anytone 6666 and am wondering if this radio will pick up only 10m? How do I listen to other ranges? Do I need to buy another radio for each band? Is there a radio that will pick everything up?
I think what I’m not understanding is if my radio does 27 to 29 but I buy an antenna that is 456. Will it still be able to hear what they’re saying?
Thank you.
drdispatch
What's the frequency, Kenneth?
Fightin' River, Michigan
The frequency range of the radio is all you'll be able to recieve. If you connect it to an antenna made for UHF, you'll still just recieve 27-29 mhz. You just won't recieve as well, because you'll have the wrong antenna. A multi-band antenna that includes the 10 meter band will work better. An antenna designed specifically for 10 meters will be best.
robertmac
One of the great things about learning about amateur radio and testing for an amateur radio ticket is the knowledge that one gains about radios and antennas. I would suggest taking a course to obtain your amateur radio ticket.
