Does Unication lurk here? G4/5 feature suggestion
kh11
Trigger the display when the volume knob is adjusted.
Solidjake
NYC
+1 on the suggestion. Would be nice to not have to push a button to activate the screen to see the volume.
IAmSixNine
Dallas, TX
If your device is plugged in then any volume adjustment will turn on the display.
If the device is running on battery power and there is no activity it sort of goes into a sleep mode. For me i just press the back arrow to turn on the screen then adjust volume. is it really that much of an inconvenience to press a button then adjust volume?
kh11
Is it really that much of an inconvenience to press a button then adjust volume?
No, but it shouldn't be necessary. Activating any control should wake up the display, just like it does on many other similar devices.
jackculb
Ohio
Alright, I'll chime in. How about a Gorilla Glass screen instead of cheap plastic?
Check out the heavy duty screen protector kit that you can purchase from Ray's Pager Sales (great seller!). I have had one on my G4 since purchasing it new and feel it was a great addition to the pager and can highly recommend it!
blackbelter
As a professional grade device the pager should be built with stronger screen . Attachments are attachments and should not be a requirement to protect the unit. I have an I watch with the gorilla glass and have never experienced a scratch on its screen.
Sanscanman
N5WRF
Acworth, GA
Once the display on my G5 times out, a volume change will not activate the display and the screen remains blank.
my G5 wakes (after about 30 seconds) upon changing the volume. I think it is just that the processor is a bit slow and it makes it seems like it is not responding.
bob550
Albany County, NY
Are you sure it's not being woken up by whatever your monitoring? I'll experience that periodically without any audio. Does this happen consistently? My G5 will not wake at all at any point.
Sanscanman
N5WRF
Acworth, GA
Nope it it will be a completely black screen with just the volume bar that will stay lit about 5 seconds and then turn off again.
