Especially since we lost Paul?
Most of the one freq DMR systems I monitor come in fine on the Unidens.Thank you. I sure wish they'd cure our SDS200 no audio on some DMR one-frequency channels!
Thank you, kruser. You helped me to get one of these two channels to work; the school. Using a dummy TG cured it, but using a dummy TG on the power channel didn't help it.Most of the one freq DMR systems I monitor come in fine on the Uniden's.
But... I also have some single-channel systems that show as Tier III systems in DSDplus that give me troubles no matter how they are programmed.
I discovered with a couple of these troubled systems that if I manually hold on any talkgroup number I'd added and then release that hold that the system then usually seems to decode very well. I don't know if that is just some kind of coincidence or something but if I don't do the TG hold and release, the system will just keep searching without ever stopping on active chatter when I'm monitoring the system with a Whistler TRX-2.
Once I do the hold and release, the Uniden will follow the TRX-2 and stop on the active chatter. Go figure.
The above does not always work but it usually does. It seems to be something to do with the conventional DMR systems that don't use a talkgroup. When I add these systems, I'll usually throw in a dummy talkgroup so I have something to hold on in order to get it decoding.
I read something here that mentioned the Uniden models expect a talkgroup and if none are used, they have the no decode problem. Not sure if that's true as I have several conventional systems that don't use TGs that decode just fine on my Uniden's. It seems to be the systems that DSD+ show as Tier III systems that have the issues.
I'm pretty sure that you will need to have at least one TG programmed. The scanner are scanning TG's in trunked systems and if none is programmed it might just skip the control channel without even checking if IDSearch are enabled. It depends of how the firmware code are written. It would also explain why a system that doesn't use a dedicated control channel, a non TierIII system, might work without any TG being programmed.Using a dummy TG cured it, but using a dummy TG on the power channel didn't help it.
For several of the previously undocumented DMR systems in my area, when using ID Search to try & determine usage, I seem to have better results if I add a 'dummy' talkgroup as a place-keeper.Most of the one freq DMR systems I monitor come in fine on the Unidens.
But... I also have some single channel systems that show as Tier III systems in DSDplus that give me troubles no matter how they are programmed.
Somewhere, in all the myriad threads that came up when the DMR upgrade was released, I think I saw a quote, possibly from UPMan (though not positive) that suggested adding the dummy TGID as wellas a Department, even though TGIDs had yet been identified.I'm pretty sure that you will need to have at least one TG programmed. The scanner are scanning TG's in trunked systems and if none is programmed it might just skip the control channel without even checking if IDSearch are enabled. It depends of how the firmware code are written. It would also explain why a system that doesn't use a dedicated control channel, a non TierIII system, might work without any TG being programmed.
It was a similar bug with NAC codes, if it was set to ignore it wouldn't decode the system and had to be set to search until the firmware code where fixed in a later release, if I remember correctly. It's probably many more bugs in such a complex firmware code that haven't been discovered or are considered being user errors or system quirks.
/Ubbe
OK, I already have TG240 and others that ends in a zero programmed, so that didn't help me. Maybe I should test with the exact same setup as you have, only program one single dummy TG that are not used in the system and then use IDSearch to monitor all TG's.I've figured out with my two problem channels that it decodes better if the dummy TG I use ends in a 0 zero.
The only purpose of the 'dummy' talkgroup and department is to jump start the ID Search process. Once you begin to find, and add, verified TGIDs, the "dummy" can be deleted. That's what I've been doing on "new" systems that I'm trying to verify.OK, I already have TG240 and others that ends in a zero programmed, so that didn't help me. Maybe I should test with the exact same setup as you have, only program one single dummy TG that are not used in the system and then use IDSearch to monitor all TG's.
It's been strange all evening here when I try and monitor the amateur site in a One Frequency DMR system. I can hold on the site and the d-error are just a dash and sometimes a zero pops up. Color codes and the rest are displayed but no TG. When i go to the same frequency programmed as conventional analog+digital it works fine with d-errors between 3-7. Filters and IFX are the same and all service types are on and I've tested all combination of filters but it never decodes a TG in DMR One system.
I will experiment with that dummy TG and also different firmware and subprocessor firmwares.
/Ubbe
