Dorchester County
maus92
OCMD
Does anyone know what baud rate the Dorchester Co. trunked system uses? I was down in Cambridge today, and I was only able to copy what sounded like a control channel (digital noise). The bc250d w/ bc25i card I was using was scanning 2 other trunked systems, AACo and UESC with no problems...
Charley
Annapolis
maus92
OCMD
Thanks for the baud rate info....turns out that I had not turned on the trunking in the arc250 software for that bank. Operator error :)
yogibear21613
Cambridge, Maryland
Re: Scanner
Mr. Tolley,
What scanner can you use other then the one that sells for 499.99 in Radio Shack that will get all of the codes?? Robert W. Bullen
tolley
Hurlock, MD
The other scanners are the Bearcat scanners that sell for around $530.00 each. You may want to check Ebay. Sometimes you can pick up a digital scanner in the 3-4 hundred dollar range.
The Bearcat snanners are the BC785d, BC250D, BC796D, and the BC296D. You may get better deals on the 785 and 250d. They came out before the 296 and 796. The 250 is handheld and the 785 is a base version.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
You might want to avoid the BC785 and 250. Apart from being discontinued, there are major 800 Mhz frequency changes coming that will not be supported by Uniden on these scanners. While they may not affect Dorchester county, if you travel to other areas, you may well run into this problem.
In addition, a seperate digital card - tbe BC25i - is required for digital reception. The 296/796 come with this standard; it's a seperate item for the 250/785, and will add to the cost.
Don't forget the upcoming BCD396T; it's also digital capable, and unfortunately just as pricey.
73s Mike
yogibear21613
Cambridge, Maryland
Re: Scanner
Thank You Mr. Tolley and ka3jjz for your input.
Cany eather of you tell me what is APCO-25 used for??
Thank you Again, Robert W. Bullen
