DOS Box or Moslo
KD0NDO
i have a Pentium 3 500mhz and want to program my saber with rss 7.01.00. will one of these work to slow my computer down enough? Safely?
mancow
N.E. Kansas
No, it doesn't mean you are out of luck you just need to find a way to boot to DOS. Does your computer support USB as a bootable device option? If so you can make a bootable USB drive and use that. Does it have a floppy drive? You could boot from the A:
KD0NDO
i can boot in in dos it is the 500 mhz the part that scars me because everywhere i looked for programming with rss say 486 or older 50mhz or slower. and if not you will brick the radio
jim202
New Orleans region
Maybe if you tried doing a search, you might find a reference to a slightly different program that I think is called "MOSLO PRO". It is available for download off the Internet for around $29. It allows you to slow down the computer to just about any speed you need.
There is also another program called "cacheoff.com that will control the computer cache. You might try running it before you start the Saber software. This program is available as a free download off the Internet.
KD0NDO
have you tried it? Is it safe?
mancow
N.E. Kansas
Try reading it first. If it does a full read with no errors you should be fine. If it doesn't it won't cause any corruption since nothing is being edited yet.
KD0NDO
sounds good. what type of processor do you use to program your sabers?
BigLebowski
Piedmont NC
I use a PII with my Sabers and Systems Sabers, just booting into DOS. Provided your RIB and cable setup is a good working one, you should have no issues.
I even did this when I lived in Otsego a few years ago!
jim202
New Orleans region
I use it quite often. I will say it again, you need to do some research on the subject. There is a couple of other sites that you should visit. One is batlabs.com and the other is Batboard • Index page and spend some time looking at the different threads and information there.
If you don't feel comfortable programming your radio, then don't do it. It seems from your comments so far that your not a regular user to programming these radios. If that is the case, then maybe you should find a radio shop or a friend to work with you.
mancow
N.E. Kansas
1.1 Ghz Centrino in a Panasonic Toughbook
You are lucky in the regard the saber software will allow you to build a default codeplug so there is no real chance of any permanent harm.
