dose anyone make a directional CB antenna?
methusaleh
New England
There are countless commercial designs from throughout the years, plus it is easy and a good learning experience to make your own.
Search the 'net, and ye shall find....
gmclam
Fair Oaks, CA
They used to, not sure exactly what is available today. Lots of people had "beam" antennas on a rotor that are "bi-directional" (forward and backward with good side rejection). There's one who's name escapes me at the moment that has 3 vertical elements, does not need a rotor, and the user can pick which of the 3 directions is active (or all of them) with a pattern just over 120 degrees.
r_eugene1
Southwest Ohio
I believe it was the Super Scanner. I have owned 2 in the past years and we a real exceptional antenna in my opinion. Always like to work the SSB band when the conditions were right. Those days bring back old memories.
w2xq
Burlington County, NJ
There were many CB beams c.1960. If you can't find one -- I have no idea if they're made any more -- you could buy a ham radio single-band 10m beam and do the math to add a bit of length to the tips to move down to 27.2 MHz or so. You have to mount the beam vertically and get it at least 1/4-wavelength above the ground. Google for amateur radio dealers or manufacturers to begin your search.
Central IL
A company called Maco still makes new beam antennas for 11 meters. Everything from a 2 element delta loop to an 8 element monster yagi.
