Double remote head!!!
scosgt
Controlling two radios (Uniden 996T and Whistler 1080) at once with Winbook 10" tablet.
996 is using the old USB-1 connection to the front of the radio (YES, you CAN get it to work under Win 8.1) the 1080 standard USB mini cable - charges and controls.
AE4VE
Warner Robins, Georgia
It will pick up both USB ports at the same time for the same program?
Nevermind..just noticed that you have two separate programs running.
Sent from my SM-N920T using Tapatalk
JamesO
McLean, VA
You are killing me, I have a WinBook 8.1 tablet here as well.
Probably time for me to start thinking about using it!
Are you just using a USB hub or how is the tablet communicating with both radios?
scosgt
One radio is plugged into the full size USB port
The other is plugged into the hub I referenced in the other post.
You can in fact run more than one instance of ProScan, so you could have two BC radios running at once off the same tablet.
scosgt
996 is plugged into the full size USB port
Whistler is plugged into the hub I mentioned on the other post, which is plugged into the charge port.
But since there is full size USB, you can just use a regular hub to run both. The Whistler, if you also want to charge, may require a powered hub, the tablet may not put out enough power to access both radios and charge the batteries.
n2pqq
I did something similar about a year ago.
One scanner 536 two ports ,two monitors , two programs
all at the same time.
https://www.youtube.com/watch?v=dGLaqhWrS6M
JamesO
McLean, VA
Wonder how well Wireless USB adapters would work in the mobile environment and if it would connect back up without problems?
alphaacres
Oswego, New York
536 three ports You can do the same with three devices Computer arc back port, Tablet Proscan front port, Cell phone siren wifi or you can put all on one computer or computers mix and match programs what ever works for you
alphaacres
Oswego, New York
What is the program on the right?
Does it offer control or only display?
Run the Remote Control Test Software
Click on RH-536HP_mkII.zip to run the test application. The scanner can be controlled using this remote software.
BCD536HPFirmwareUpdate < UnidenMan4 < TWiki
http://info.uniden.com/twiki/pub/UnidenMan4/BCD536HPFirmwareUpdate/RH-536HP_mkII.zip
For Audio I like to use this if using above program
http://forums.radioreference.com/uniden-software-discussion/308095-bcd536hp-audio-player.html
