Douglas County Fire Info
NVSHMOO
Reno NV
What Are The Frequencys And Pls For Douglas County Fire Commands 1-3 ?
And Who Uses 154.040 Mhz In The Minden Area ? Shannon
NVSHMOO
Reno NV
Is 155.055 Mhz And 155.715 Tahoe-douglas Fire Dist Fire Tac Channels
Shannon
NVSHMOO
Reno NV
What Are The Frequencies For Douglas County Sheriff Channels 2,3 And 4 ?
159.0375 Mhz Is A Interop Repeater On East Peak-shannon
NVSHMOO
Reno NV
Dcso Channel 1 Is 154.740 Mhz Pl 100.0 Channel 2 154.890 Mhz Pl 100.0
Unknown Channel 155.130 Mhz Pl 100.0- Shannon Reno Nv.
NVSHMOO
Reno NV
I Belive Tahoe-douglas And East Fork Fpd Are Dispatched By Douglas
County In Minden. Ill Answer My Own Question 155.055 Is Tdfpd Tac And
155.715 Mhz I Dont Know Also 154.040 Mhz Was Used A Long Time Ago As
A Tac For East Fork Fpd Shannon Reno Nv.
rhvfd10
Douglas County, Nevada
Indeed they are. You will here Tahoe Douglas dispatcher call sign "Tahoe" and EFK as "Douglas" though the same dispatcher is dispatching for both agencies. Douglas Co also dispatches for Alpine Co, CA Fire and Sheriff along with Washoe Tribe PD. Like I said, I know East Fork's radio setup much better than the others and I'd be happy to help with any other questions on it.
NVSHMOO
Reno NV
In Reno I Can Receive 155.085 Mhz East Fork Fire Dispatch And 153.800 Mhz
Alpine County Sheriff. I Used To Get 154.400 Mhz Placer County Fire +
154.740 Mhz Douglas County Sheriff (weak) Shannon
NVSHMOO
Reno NV
I Have Not Received Plumas County On 155.085 Mhz I Have Received
Sierra County Sheriff 153.785 Mhz And Pnf Forest Net 170.550 Mhz
In The Past I Received Mono County Sheriff 154.800 Mhz Shannon Reno,nv
gvranchosbill
Douglas County,NV (4,859 Ft)
I should have some info for you.
155.0850 for East fork and 153.8000 Alpine Co S.O. Repeaters are both on Leviathan Pk 8,942'ELEV
and farther east towards the center of the carson valley line of sight to reno skirting by Hot Spring's Mtn,Mclellan PK & Slide Mtn.
154.7400 Repeater is on East PK 9,591'ELEV and is tucked West out of the line of sight to Reno And you
have all of the eastern slope of the sierra's obstructing your line of sight ,Genoa PK being one of them.
I hope this helps out. Bill
gvranchosbill
159.0375 is the input freq to 156.2250 Douglas County SAR CH-01 PL tone's are 141.3 HZ input & output.
155.1600 is now SAR CH-02 Simplex CSQ, (SAR Member's Confirmed this CH info 02/15/09)
155.1300 repeater output tone 100.0 HZ, 155.8500 input freq, tone 114.8 HZ is active.
155.1300 simplex ,tone 167.9 HZ is now Douglas County Main Jail Control Minden.
And just became active is 151.4525 output,tone 127.3 HZ input freq is 155.6550 tone 141.3 HZ.
And also active 159.2475 output,tone 067.0 Hz input freq is 155.6550 tone 141.3 HZ.
they xmit in simulcast unkown use. Only 151.4525 & 155.6550 show license info ,FCC Database.
155.6550 was being used for the Jail then they changed that and have used it for SWAT/SET Team's
simplex PL 100.0 HZ.
Iam sure there is more to follow,does this info help out? Bill
NVSHMOO
Reno NV
Try 159.600 Mhz Pl 136.5 Eldorado So Eastern Primary (genoa Peak)
Also Licenced Is 155.910 Mhz In The Wellington Area I Can Receive 153.800 And
155.085 Clear In Southwest Reno Also 460.150 Mhz With A Pl Of 100.0 Listed As
State I Heard It As A Bus/transit Company Shannon
gvranchosbill
Re: 159.6000,155.9100,460.1500
E.D.S.O. Primary East 159.6000 Repeater Output/Pl 136.5 (Genoa Pk,W/Of Genoa,NV/Scout Pk,W/Of South Lake Tahoe,CA). Repeater Input 160.8750 [PL 167.9 Genoa Pk/Pl 110.9 Scout Pk].
155.9100 From What I Can Gather Is TOPAZ RANCH ESTATE'S GENERAL IMPROVEMENT DISTRICT,
I Have Been Monitoring But All I Hear Is Churchill Co S.O. Input. I Could Be That Their Simplex Mobile's
Out Of My Range Due To Mountain's, I Have Planned On Monitoring Next Time Iam Down There.
460.1500 Never Have Heard Anything On That Freq, Their Are Several UHF Link's Down Here Mostly
On 453,458,465 Mhz But I Would Have Heard Activity On 460.1500 If It Was In Douglas CO.
Not Much Help This Time gvranchosbill
gvranchosbill
RE: 151.4525,155.6550 New Info
151.4525 Is One Of Douglas CO's New Multi-Tac/Inter-Op Repeater's Output Pl 127.3
155.6550 Input CSQ To The Multi-Tac Portion, I Heard East Fork Fire On Inter-Ops Mutual Aid To Carson City. This Must Be For North CO.
gvranchosbill
RE: Freqs,Pl's For CMD CH's 01,02,03 & 154.0400
WPYL312 E.F.F. & P.D.
Command CH-01 155.0850 Simplex Pl 100.0
Command Ch-02 155.0850 Repeater Output,155.7750 Input Pl 100.0
Command/Tac Ch-03 154.2800 White Fire CH-01 CSQ
As Far As I Know Their Are 9 Channel's For East Fork Fire & Paramedic District
Never Have Heard Anything On 154.0400 And Ive Been Searching Band's Down Here For Several Year's.
gvranchosbill
rhvfd10
gvranchosbill
EFFPD actually only owns two of the channels
EF Local and EF Repeater (ch 1 and 2 on all EFK radios) WPYL312
the tac channels are the standard NV and CA Whitefires
ch 3 = White 1
ch 4 = white 2
ch 5 = white 3
ch 6 = 'Mutual aid 4'
ch 7 = NDF Red
ch 8 = NDF local
ch 9 = CCFD (usually)
ch 10 = Alpine Co
after that the channels that are programmed vary widely from radio to radio but usually include Mono co Ca fire, Tahoe Douglas fire. Lyon county fire on at least one repeater, USFS and BLM locals, and DCSO
The hope is to standardize the radio channels for all radios district wide but it is still a work in progress
exsierra
SAR Pager Tones
Does anyone have the Douglas County Search and Rescue pager tones (two tone freqs) they could post? I believe that they are toned out on 154.740, and the pagers are indicated as such:
10-DCSO Liason
12-Team Leaders
13-Operations Leader
14-All members
15-Operations Leader
17-Operations Leader
gvranchosbill
I know this is very old thread, but in regards to two-tone sar pager tones i have them and yes they are still paged on law primary consisting of multiple freqs and sites transmitting in simulcast 154.7400 being east peak rptr covering entire county.
