Douglas County Sheriff Ch. 1
natedawg1604
Colorado
Okay I pulled up the archive you referenced and I am hearing some kind of "squelch" sound, that is really weird. For some reason the audio on my scanner sounds a lot cleaner, I'm not hearing this at all.
This could could be crosstalk in the console, bad cabling/connectors/solder joints, a crappy A/D converter (they abound), wacky gain settings, excessive devices/adapters in the signal chain, or who knows what else. My scanner must be filtering this stuff out, I don't know how or why...
ecanderson
Colorado
Sorry, guess I missed the news. Try it anyway. Be sure to log in, or try to, then you'll go in with the permissions you were granted. No guarantees, I guess.
Yeah, they spun off the audio side, and decided to keep the books entirely separate and wouldn't allow feed providers to pick which of the two services they would prefer in 'payment' for the feed. So providers got the archives or nothing, and had to pick up the price for the database API separately again.
Steve2003
Colorado
154.7850MHz used to be their backup frequency when they first went digital back in 1998. You could always give it a listen and see if you can pick something up.
lazierfan
Map Page AA-18
04Z1V6
Castle Rock, Co.
Don't forget gentlemen Douglas County will be doing lots of work as they install there own system and move away from the CCNC. They are tired of the way the CCNC takes lots of money from a few and ask little money from others.
natedawg1604
Colorado
Are you referring to a "second" FRCC, or are they moving to the existing FRCC??
Spitfire8520
I might be completely clueless! =)
Colorado
I believe there were mentioning and rumors floating around that Douglas County was considering joining up with FRCC earlier this year, but I don't think there's been talk of a firm commitment on any of that. I believe that Douglas County put in a request to the FCC for a new simulcast site in southern Douglas County (where coverage is terrible, even along parts of I-25) in which they noted that it will be part of the State DTRS, which adds to much of the unknown.
As for the issue of the weird voice grants and squelch noise, it may or may not be related to communications work as I know that much of state is undergoing a software update on system. I get this feeling that end users don't notice it or don't care as fire side has been dealing with it for more than a year now. I do find it weird that the issue seems to be migrating from TG 1053 to TG 1033. I don't believe any other dispatch center or talkgroup on DTRS has run into a similar issue from listening and looking Pro96Com logs.
dw2872
Colorado
I just checked my Pro96Com logs from the past 48 hours, it looks like this issue has come up twice in the past two days. One event was today starting at 08:06 until 14:30. The other event was yesterday from 13:02 to 15:04. I don't know what the issue is exactly, nor will I probably ever know the exact cause. Another theory of mine also involves some type of incorrectly setup VHF to DTRS patch that involves their VHF repeaters that might feedback into itself, especially because there's two separate fire side VHF repeaters with different CTCSS tones. The two separate repeaters might interfere with each other and cause this issue. I don't know why it would be affecting the law side of things though.
I was logging the Cheyenne Mountain site on my Pro96com recently and saw that "radio ID 0" popping up and i had never seen that before.
Thanks to you, now I know what that was about. Thanks!
I am away from home so i will have to re-look at it, but I think when I saw it, it was on the FD talkgroup. I wonder if it has to do with a specific dispatch console that has been used on the FD side but now is being used periodically on the SO side. Since the RID says 0, the only way to find out is to ask a dispatcher.
Sent from my iPad using Tapatalk HD
natedawg1604
Colorado
Have you ever heard this squelch noise on your 396XT? I'm having a great deal of trouble hearing this on mine, but if the problem originates at the Dispatch Console I don't know why certain scanners would be filtering it out. Maybe it comes and goes at random intervals, which would also be weird...
dw2872
Colorado
I think it has something to do with each scanner delay settings and whether you are in scan mode or held on a control channel and talk group. I have not heard it yet on my 396XT but have not held it on the control channel and that talk group yet. I will try when I am home.
lazierfan
Map Page AA-18
As mentioned earlier by Spitfire, 1053 DCFD ch-1 does this noise 24/7/365 and is also apparent, as it was on the feed archives for 1033 DCSO ch1. Again, my delay is set for 2000 ms and I heard it during scan or held on the talk group. On DCSO it comes and goes.
natedawg1604
Colorado
How can you "hold" a control channel and a talk group simultaneously with the 396XT? Are you thinking of holding on a talk group while listening to a single site?
dw2872
Colorado
Yes. I just hit the hold button while on the site and the TG I want to keep listening to. It holds on that TG and does not change sites. That is the way my database in my scanner is set up.
natedawg1604
Colorado
Oh I got yah; I always run 1 site per quick key, and I almost always listen to one site at a time. In any event, when I hold on Douglas County Fire or SO Primary (on a single site) I don't hear anything unusual, and I have very good headphones. Please try it on your scanner, I feel like I'm "out of the loop" on this one...
04Z1V6
Castle Rock, Co.
No mention of the FRCC from me the rumor I had heard was they were thinking about building a totally separate system. That's why they call them rumors.
