Downgrade from 1.34 to 1.33
mdsxfire
EDBM
Uxbridge, north of the river Thames
Has anyone successfully went to 1.33 from 1.34. We just received some refurbished pagers and they came with 1.34. With the “announcement” display instead of showing our dispatch TG display we want to go back but it is failing and closing the updater when we do
You can not go backwards from 1.34. Check the below linked post, I think there was a work around for the issue.
62Truck
Ordinary Subscriber
Uranus
What version of PPS are you currently using? Try changing Announcement group ID setting form 0 to 1 under your knob positions. This will be far more easier they trying to roll back the firmware.
Crocker_B
Brandon Crocker
Goldsboro, North Carolina
Please share how you did this since it seems no one else has figured it out or admitted they'd done it.
So I spoke with one of the Tech Support specialist from Unication. Apparently Unication has blocked the downgrading capabilities for Newer Versions or at least the Newer Pagers. This is all due to Unication putting a new processor in the latest pagers and will not allow them to go either past or just down in general to certain firmware's.
jtwalker
Gettysburg, PA & Fenwick Island, DE
I think I had read that people had went back further (to 1.1 or 1.30) from 1.34 and then forward to 1.33. I am not advocating this I am just telling you what I read that others claimed to have done. Might end up with a brick.
belvdr
No longer interested in living
The newer hardware likely requires a minimum version of firmware. For the older devices, I read the same: rollback to 1.20 then to 1.31/1.33.
