traperjeff
I thought I saw somewhere that we can import from the database into win 96. Is that true and if so how do you do it.
Thanks.
Thanks.
I don't believe that the Pro-70 has any way of being connected to a computer.Navycop said:Is there one for Pro-70?
You have two EDACS systems Networked in Manatee CO, each must be imported into separate banks. Check the first group of freqs and selected or all TG's then import. Then uncheck the first group and check the second set of freqs then import to another bank. Works as designed.traperjeff said:Cool it works for everything but the system I need.....
Error parsing the XML.....
You're correct about Sarasota. The admins are usually good at fixing problems, why don't you click on the submissions link in the data page and report the error as reported by Win96r?traperjeff said:looking at Sarasota county mot county system.....
The problem (at least, what's killing the XML parser at the moment) is the location information in the site data. location="27° 34.98N 82° 32.18W" isn't valid XML.traperjeff said:Cool it works for everything but the system I need.....
Okay, I temporarly fixed the problem. You should be able to import this now.traperjeff said:Ok I give up who do I contact about getting this problem fixed.......
Don, you need to adjust the software, this will happen again and again as the ° symbol is going to appear over and and over.DonS said:The problem (at least, what's killing the XML parser at the moment) is the location information in the site data. location="27° 34.98N 82° 32.18W" isn't valid XML.
Well Jeff, the Pro-96 can only handle 150 Talkgroups per bank (5 ID Banks of 50 each). You have to choose the ones you want. If you want to listen to all of them you will have to re-import to a new bank, and choose another 150. I would start by ignoring all the UNK and Blank ones, I am not sure why they are in there to begin with, it is against site policy to put unknown information in the DB.traperjeff said:Thanks Lou, I can import now but not even a third of the talk groups import, Any ideas...Jeff
Jeff, I ahve tried to see what was wrong with it, even changed the "Blank" talkgroups to UNK but even that doesn't seem to fix the problem. There are more problmes on this system. I am going to contact the admin who put the info in and let him fix it.traperjeff said:I understand that but it only has 46 talk groups available.......That didn't even fill 2 banks....... Thank you for your help.........Jeff
