DP 3400 won't charge
crappy
I have a Impres charger and 3 batteries. All 3 batteries are dead but the light on the charger goes green when installed into the charger. What does this mean? Thanks
crappy
Anyone? I am new to Motorola and have already ordered a second charger and it does the same thing. Thanks
gtaman
GALAXY 19 91.0° W
Put the battery in then remove it. Them wait 2 seconds and put it back in. The light should be orange which will condition them. This happens to impres batteries when they sit awhile.
crappy
Thanks for the reply. I tried what you said but the light stays green. Do you think all 3 batteries are no good?
clbsquared
Isle of Wight County
Some chargers tell you that even if the light turns green and indicates a full charge as soon as the battery is placed in the charger, you should leave it in the charger for 24 hours to help recondition an older weaker battery. Read the product tag on the bottom of the charger. If it's like other Motorola chargers, it will have some notes regarding charging procedures.
Sent from my HTC One A9 using Tapatalk
crappy
Update
All three batteries are no good. I ordered a new one and it charged fine. I just wish the charger would have told me that they were no good instead of showing green no matter what I did. Thanks for the help.
gtaman
GALAXY 19 91.0° W
Odd usually they flash red when they have gone bad.
ME801
NV
yes, normally they flash red when there done. Chalk it up to unsupported "options".
crappy
another update
Turns out the chargers I ordered are no good. The new battery charged fine when I first received it but would not charge when I left the radio on and fully discharged the battery. Again the charger would light green just like before. I went to a Motorola dealer and purchased the correct charger which works on the new battery and two of the older batteries I had. Should have purchased a genuine motorola charger first instead of a knock off to save a few bucks. Thanks.
