DP4800 power down fault
TrboMonitor
Hi all,
I have a strange fault that seems to have appeared on my DP4800, Firmware version R02.40.00
After the radio has been on for a period of hours and while scanning all 15 scan members, all of a sudden the radio turns its self Off and then back On again with no intervention from me! once i have put my password in, the radio resumes back to normal. this has happened a total of four times now since the firmware upgrade one week ago. I did try and read and reprogram the radio myself with, what i now know is the A programming cable as all i got on the display was the incorrect accessory warning. I had the radio then re-programmed and firmware updated by a friend using the B version programming cable, using CPS v11 running on a windows 8 laptop.
Is this a radio fault? Codeplug and or firmware issue?
Cheers
N4KVE
PALM BEACH, FLORIDA
Either turn off scan, or turn off "enhanced audio" & the problem will go away. It's commonly known the 2.4 fw upgrade with scan, & enhanced audio on at the same time will cause this. Remove one from the equation until "M" thinks of a fix. GARY
