DPD GMRS Antenna
tpp517
Dennis, MA
Does anyone have any experience with DPD Productions GMRS antenna?
aprswatcher
Lewistown, Montana
I don’t have the DPD GMRS antenna, but I do have a DPD aviation Omni X antenna and a DPD ADSB antenna.
They are very well built and I have never had any problems with either one.
That being said I don’t think you will be unhappy with the GMRS antenna.
73, Rex 👍
prcguy
The specs say its 1/2 wavelength. You can do much better and the antenna is more important than the radio if your going for distance.
NMO's installed, while-u-wait.
mmckenna - Can you please provide an example or two, thanks.
Laird makes a couple. If you shop around, you can find them for the same price, or a bit cheaper.
Just make sure you are comparing dBi and dBi. Different companies use different references. dBd isn't the same as dBi.
