KeithJoseph
Still working on my amateur radio callsign.
Why can't I hear both sides of the conversation. Only hear dispatch and it comes across on two of the apco channels at the same time
Which repeaters?the repeaters have no licence any one know why not?
What do you mean they don't have licenses? They do.the DPS P 25 conventional repeaters.
why does RR not show them?
And Texas Parks and wildlife does not use their radios I don't know anybody programs those frequencies they do not use them
TPWD uses their radios every day. Most use the local park channels, a variety of TPWD owned repeaters, DPS channel, County repeaters or the local trunking system. TPWD also has access to DPS channels and uses them from time to time.
TFS primarily uses their travel channel (compact) and other interop channels. TFS in the east Texas area utilizes some of their local repeaters. They have an MOU with DPS but don't use their repeaters unless absolutely needed
DPS does the same thing. They will use local repeaters or trunking systems. They will also rely on MDTs. If you are wanting to Rx the units then you need to be close to the repeater they are using or have a good antenna setup. There are 60+ DPS repeaters throughout the state and they utilize the same 30(-+) pairs
IF you're in Abilene they are probably using the P25 system. DPS recently redid their call signs as well and include a numeric
