DRC-200 Programing Cable
K3LSY
Hi all,
I have recently picked up a DRC-200 repeater, and I am looking at building a programming cable vs buying one. Does anyone have plans for one? Is it a straight serial to mic jack, or does it have more components than that?
Thanks!
kb4cvn
Silent Key
Nowhere near a paved road, away from the maddening
DRC-200 Programming Interface and notes
See attached PDF for the programming interface.
FOR DRC-200 REPEATER
INSTRUCTION SHEET
For this program to configure / read a KRD Series Repeater, the
following is needed:
A. An IBM-compatible computer with at least 256K Bytes of
memory.
B. MSDOS 2.1 or higher operating system.
C. An IA4500 Interface Adapter.
INTERCONNECTION
The IA4500 Interface cable with DB25 connector connects to the
computer serial communications port, COMM1 or COMM2. The 6 wire
flat cable from the IA4500 plugs into the REPEATER MIC Jack.
There is logic signal level conversion circuitry within the
IA4500 DB25 plug assembly.
1. Connect the IA4500 Adapter to the computer's COM1 or COM2 port.
2. Connect the 6-conductor reverse-wired Modular cable to the
IA4500 and to the Repeater's MIC Jack.
3. Turn on the Repeater. The Repeater should emit a Beep.
4. Insert the disk. (It is highly recommended that a WORK COPY
be made of this disk and only use it for actual programming
purposes. The program is menu-driven for all pertinet commands.
5. Type in DRC200 and press ENTER (or RETURN) for COM1, or type
in DRC200/2 and press ENTER for COM2.
