Driveing Vacation with the 436 HP
Janleo1
Santa Clarita Ca
I will be driving with the 436 HP wile on a road trip from Los Angles out 395 to our first stop Carson City NV, second stop out Hwy 80 to Wendover UT then continue on 80 to Hwy 287 to Lander Wy.
on the way back we are we are coming back down the Hwy 191 to Flagstaff AZ.
then Back Home.
I have a GPS antenna and want to know how to make this work.
if I use the data base will it track us as we move or do I need to program all the states and county's in to a favorite list.
thanks,
Jan
Jay911
Bragg Creek, Alberta
Either-or, it's your choice. With the GPS connected, as you drive, it will turn on and off systems as you get into range of them. Every now and then you might see the screen show some loading prompts when you get close to state lines (it reloads when a new state is in range, or goes out of range). You can leave it with the entire full database enabled and choose what service types you want to hear, or if you know beforehand specifically what channels you want, you can make a favorites list.
If you expect to want to hear everything, just leave it be after you plug in the GPS, and let the full database and the GPS do all the work. :)
