Driver Needed
daviwalker
Laurens, SC
I have a Radio Shack Pro 2096 and it's been over 10 years since it was
programmed. I'm using windows 10 with a 32 bit operating system and
x64-based processor. I need help getting the driver to use with
programming my scanner. Can you advise? I purchased some time ago
the programming cable and it came with a driver but it will not work with
windows 10.
tvengr
Well Known Member
Baltimore County, MD
I'm using a Radio Shack 20-546 cable with the original driver and never had a problem with Windows 10. You need to use the mono adapter with the Pro-96 and Pro-2096. I use ARC96 software.
kc0kp
DM79np
I have three of the 20-456 cables. Windows 10 loads the driver automatically if you have an internet connection. I believe it is a FTDI chip. I use Win500.
Why do I have so many? The interface is so versatile. I use it to program my VX-8 and for Cat control on my IC-736. I also use it with an adapter to program wildland BK DPH radios. It can be adapted to just about anything that needed an RS232 interface.
kruser
West St Louis County, MO
Where do you get ARC96 software? thank you for the reply.
