Drone Antenna Hang in SONH?
N4SRN
Bedford, NH
Are there any commercial drone operators who will hang an antenna in SoNH (MHT area)?
Bret/N4SRN
n1das
Nashua, NH
I think you mean Drone op's? ;)
Should be drone ops, short for drone operators. (No apostrophe for plurals.)
Not sure what the OP is asking. OP, are you looking for someone to hang or install an antenna for you?
N4SRN
Bedford, NH
I actually found a guy who does drone camera/video work that has hung 60ft XMAS tree light strings on tall trees. This might just work!
The antenna is a MyAntennas 130ft end fed that will run from my attic window up and over the tall tree tops behind my house. There’s clear space to run that wire from the window to the street in front of my house, so the end can be lifted on a little clamp and flown up and over the trees, to pull loose. I’ll add a 10ft line with 1oz weight to the end, so it will drop through the branches and hopefully given and take as the winds jostle the trees.
Litning
New Hampshire
I have recently done this using 50lb fishing test line with a 1" wrench. if works well, but with leaves on the trees sometimes it's hard to get near the trunk of the tree. plan on multiple attempts
