DSD 1.7 on Ubuntu 20.04 audio Issue!!
jshg46
I don't think I would have to use sink, but im not getting any input from scanner.
lwvmobile
DSD-FME
Lafayette County, FL
No, you don't need the sink for a disc tap, if you aren't getting any input or output, look at using pulsemixer, and making sure dsd-fme is listening to the right input and playing out to the right output. If you are still using headless, you will need to open another terminal (either with another ssh session, or using alt+ctrl+F2 to open a new TTY) and have pulsemixer open at the same time as dsd-fme. One thing I've noticed on headless is the default state of output is mute for some reason, so with pulse mixer, you can hit ? key and it will show you commands, if the bars are blue, then its muted, so unmute if needed.
