DSD+ 1.80 CC mode
garys
Texas
I think I know the answer, but just want to confirm. Can I feed the Control Channel with signal from SDRSharp or do I need to use FMP?
I know that the voice channel needs to be a dongle and FMP.
garys
Texas
I'm monitoring a DMR repeater, so I don't think that Unitrunker will work. Before I had DSD+ I tried to use Unitrunker with two different dongles, but my computer crashed, so I gave up.
I can use my 436HP or 536HP for following the P25 trunk system near me, so DSD+ will be used for DMR which a lot of the private ambulance services in the area use.
That way, when Uniden releases the DMR firmware upgrade, I'll just have to plug the talk groups in! :lol:
I actually use a second dongle and let Unitrunker handle the CC and voice channel switching. From there, I pipe it to DSD+ over VBCable. Works great, and I never have to mess with SDR# or FMP. ~$40 spent for a second digital scanner ain't bad! ;)
-AZ
AtomicTaco
From the readme:
DSDPlus said:
The control signal source can be any NFM receiver whose flat audio is piped to DSD+ via a mic or line in input, or an SDR device (DVB-T dongle, Airspy, etc.) whose demodulated audio is piped to DSD+ via Virtual Audio Cable or VB-Cable.
DSDPlus
SDRSharp is ok for the CC side if your PC can handle SDR# + FMP + DSD+ + DSD+...
vince48
Central Valley, CA.
-AZ
AZ
what type of system are you monitoring with UT?
