DSD+ and DMR Simplex
dtscho
Fredericksburg, VA
A hotel in Richmond, VA recently switched to what I believe is DMR simplex. I used DSD+ 1.074 with FMP to try to monitor and get information on color code, group, etc. The program didn't respond at all when there were voice transmissions (I saw employees talking into their radios). I checked to make sure the program was working on other DMR transmissions - everything was fine. Here are other things I did, all to no avail:
- changed the PPM correction slightly, even though it looked good where it was
- varied the gain, to make sure the signal wasn't overloading DSD+
- ran DSD+ to only decode DMR (-fr)
- ran DSD+ to decode dPMR (-fm)
- tried using SDR# to feed audio into DSD+
- tried using SDR# with "WinDSD" version 2
The audio definitely sounded like other DMR simplex audio I've heard.
Here's a link to a raw audio sample, recorded using the "R" command in DSD+:
https://www.dropbox.com/s/5nqz3s2c89oamv9/DSDPlus-Raw-Input_2015-07-13@132712.wav?dl=0
Here's the link to the FCC license for the hotel:
WQJA565 (APPLE SEVEN HOSPITALITY DBA MARRIOTT RICHMOND) FCC Callsign Details
Anyone have ideas? It was frustrating not getting any results, even while seeing people using the radios.
Thanks,
Dave
SOFA_KING
SE Florida
I have no experience in DSD+ or SDR, but some with DMR and simplex. So excuse me if this doesn't help...
DMR simplex (and repeater input transmissions) are pulsed TDMA of only one time slot from subscriber units, as opposed to repeaters that transmit both time slots at the same time (not pulsed, but continuous). Does SDR and DSD+ have any ability to time sync the TDMA pulses? Could that be the issue?
Phil
SOFA_KING
SE Florida
Very good read. Thanks!
Someday I have to delve into this SDR stuff. I'm not a huge fan of needing a computer to decode digital transmissions, but if scanner manufactures don't produce the "all-in-one" solution many of us want, it may be the only alternative.
Good luck on solving your problem. Sorry I couldn't help.
Phil
RayAir
I'm using DSD+ 1.074 and can verify it will decode DMR simplex. I've tried it with my own radios and received other radios in direct mode.
It is true that you need a repeater to sync the time slots, but this is irrelevant to receiving DMR simplex.
Make sure you're receiving on the exact frequency and you have a clean audio source signal with decent signal strength.
Sometimes if I'm slightly off on the frequency DSD won't decode.
I don't have to do anything special with DSD to receive DMR simplex either. It does it fine by just opening the application.
I3YBD
Hola Dave
I can not do Donwload of audio files, by 404 not found?
Ciao Maurizio
racingfan360
I appreciate it's not much help but:
- it does indeed sound like DMR simplex
- if it is, DSD+ should decode it ok
- I've tried your sample and have gotten nowhere. It doesn't sound/look like a great quality sample though
All my experience with decoding DMR simplex is with a tapped scanner. Has anyone tested/verified DMR simplex decoding with FMP yet?
Forts
Ontario, Canada
You mentioned you were able to see staff talking in their radios... how close to them were you while recording your sample? It's possible you are too close to the transmitting radios to get a clean decode.
For example, if I start up DSD+ and key up my TRBO portable while standing on the other side of the room, it won't decode. Tons of errors. If I go outside and stand at the end of my driveway... no problem.
racingfan360
Forts...I think we're both familiar with that phenomenon. The issue with this sample from Dave is that there is no decode at all (I can get DMR decode but with lots of errors by transmitting too close to the receiver).
Dave - are you sure you're on-frequency and also what's the emission type of the channel you're tuned to?
dtscho
Fredericksburg, VA
Yes, I thought about being too close to the transmitting radios. But the employees that I observed talking were at least thirty to fifty feet away from me, to say nothing of the employees transmitting from other floors of the hotel. As I mentioned in my original post, I also turned the gain down significantly in FMP.
Yes, I checked several times to make sure I was on-frequency. And I also tried decoding other DMR signals, and was successful. The emission type of the frequencies I was trying to decode is in the license link: 7K60FXE.
Thanks,
Dave
dtscho
Fredericksburg, VA
So we may be seeing a "new" type of DMR simplex. That's kind of what I was thinking after repeated unsuccessful attempts at decoding. Thanks.
DSDPlus, are you able to take a look at the recorded file in the original message and see if this is something you could add to a future release of DSD+?
Dave
dtscho
Fredericksburg, VA
Almost certain it was a Motorola. It looked sort of like an XPR3000/XPR3500, but the speaker grill was a bit different.
Dave
Forts
Ontario, Canada
I should have an XPR3500 to play with next week. I'll check it out with DSD+ and see if I have any issues. Perhaps it's something to do with the 2nd gen radios supporting both time slot operation on simplex.
racingfan360
Dave...
Can you just confirm, have you been able to decode DMR simplex before using your setup?
