I'm monitoring this local DMR T3 (Hytera) System with DSD. The issue I'm having is that I can only hear half of the transmissions. From what I understand from DSD, and I still don't know a lot, I need to define the Channel IDs/LCNs/LSNs and the Frequencies in the .frequencies file in order to properly decode DMR Audio. I may be wrong. So I defined all the Channel IDs pertaining to the site im monitoring, turned on "Synthesize all Digital Voice", and set the volume all the way up...but I seem to still be missing some audio. Can someone point me in the right direction? I'm using the latest release of DSD
Hey
@seagravebuff60 , DSD is confusing with DMR systems, it's not just hytera.
You have to "code" the dsdplus.frequencies file for that system.
File format is:
; protocol, networkID, siteNumber, OTAchannelNumber, TXfrequency, RXfrequency, sortOrder
; for TIII, siteNumber format = area.site
NetworkID is the number after the L
siteNumber is the digits after the L#.
OTA is the LSN. Dsd using logical slot number while uniden uses logical channel number
TX and RX frequency. I ONLY fill in the TX frequency
TX use the frequency you find
RX use 0.0
sortorder, i leave as 0 since it doesn't do anything except put them in order in the frequency window- i find it useless
If you use tx/rx as the same thing, it will ONLY squelch open when they were to do a simplex talk, don't want that to happen
You have to keep poking around FMP. In a sense, you have to go on a hunt while using FMP bu clicking on any signals that it will decode.
When it decodes, make sure the network and site numbers all match, if they do add it to that same "block" for that system/site.
You can make notes by add ";" at line start to type in what they are.
Feel free to DM or reply on here for more help
