- Joined
- Jun 13, 2002
- Messages
- 6,092
I was working on decoding a NXDN network in Daphne, AL this morning. I had DSDplus.frequencies set up with the information and was receiving the control channel data. I was seeing all of the information in the CC console window. Everything was working correctly, except DSD-VC wasn't decoding the data and providing voice.
I made a couple of adjustments to the DSDplus.frequencies files and everything started working correctly except that FMP24-CC need a little bit of frequency correction.
Suddenly everything stopped working. FMP24-CC is receiving, it's passing signal to DSD-CC. I know that because the DSD-CC source audio is showing good signal. DSD-CC itself is doing nothing. There is no indication that it is seeing the signal from FMP24-CC, although I know it's there.
I tested this all by using SDR# and feeding signal to DSDPlus via VB Cable. Using that, I see control channel data perfectly, but when I closed that down and went back to FMP24 as the signal source, nothing worked.
I can even use SDR# as the source feeding into DSD-CC and see the correct information.
Whatever I do, I can't seem to get FMP24-CC to send data to DSD_CC. Or rather, I can't get DSD-CC to see any data from FMP24-CC.
Does anyone have any suggestions or ideas.
