dsd decoding and provoice conventional
dsd decoding and provoice conventional Or Talk around
i was trying to decode provoice conventional Frequency with dsd and it did not work
one question is is this not supported due to inverted signal does dsd have a provoice
signal invert setting
woodpecker
Were you running it with the -fp option?
Radioman96p71
ProVoice in conventional mode has different preamble than a trunked signal. Also, trunked ProVoice is inverted by default. In order to decode PV conventional you will need to edit the source code and recompile it with the proper preamble.
