dsd error
Joe1938
Albuquerque, NM
I am using a Lenovo T-400 with Ubuntu 13.04. after getting every thing installed for dsd and using an
iMic for input from a discriminator tap on my scanner, when I type dsd on the terminal it returns the following:
"my name"@user-ThinkPad-T400:~$ dsd
Digital Speech Decoder 1.7.0-dev (build:GIT-NOTFOUND)
mbelib version 1.2.5
Error, couldn't open /dev/audio
can anyone help fix this? Keep in mind that I do not have much experience with Ubuntu.
Joe1938
fmj
Dearborn, MI
/dev/audio is a deprecated, legacy audio device. Ubuntu no longer supports /dev/audio without emulation. Unfortunately I'm not well versed with Linux either, so I wouldn't now how to fix it. Google might help though :)
If you're up for using windows, you can install DSD+, which doesn't require much preconfiguration, it also decodes better, and lets you choose your audio input/output specifically.
deboe
Ca
Little late.. But you can install/use the padsp utilty.
It builds a virtual /dev/audio device while running. You need to add it before your call to dsd
padsp ./dsd xxxxx should work.
Krainium
Pueblo West, CO
padsp
Yes, padsp works. It took me a day to figure that out on my Fedora Linux box! Just wanted to mention that the audio device name when running it this way becomes /dev/dsp. So run dsd from the command line like so:
padsp dsd -i /dev/dsp -o /dev/dsp
~k
