Dsd error
riccom
Upstate S.C.
Kansas City Mo
What does this mean and how can I fix it on a laptop with ex and desktop running 7
Sent from my Torque using Tapatalk
RadioPatriots
Florida
Speaking simply, there are three typical reason (although not complete) that a program will cause this type of violation error. DSD is probably trying to do or gain access to the following:
A. Another program's memory spaces without proper permissions.
B. Data that is past the end of a block of data. This may or may not cause the error depending on what's using the memory at the time.
C. It may be trying to call a string function and passing that function a pointer to a memory address that hasn't been initialized or contains zero/nothing.
DSD is not playing well with something. As a cursory "debugging" procedure, try shutting down all other programs that may be running and killing all non-essential processes immediately after boot. Then try running DSD and see if you still get the violation.
frazpo
SW Mo
Your running "X" ?? Can you copy and run the dsd directory on another computer?
frazpo
SW Mo
I think you have corrupt file in the dsd. Download it again and reinstall. There was another poster a week or so ago that had same issue. Have you tried another dsd exe file?
frazpo
SW Mo
Yes I did 1.6 and 1.4 same issue
With same Cygwin file? Have you tried another cygwin download or version??
So you have ruled out the DSD exe files, the computer, the windows version.
Is this correct?
riccom
Upstate S.C.
Kansas City Mo
Yes and tried the given link from the forum, and running 32 bit windows on both systems
frazpo
SW Mo
The research I have done leads to everything from cygwin files to permission issues. This is why I thought you should download another Cygwin.dll in hopes that yours was corrupted some how.
RadioPatriots
Florida
Does someone have a working DSD folder/files that they can zip and kindly upload to a file-storage site for riccom to try? It would help to rule out any of his files or file sources.
EDIT: and am I correct in that you have tried this on two different machines as well?
riccom
Upstate S.C.
Kansas City Mo
Radio . Yes sir I have, on my desktop and laptop same results
riccom
Upstate S.C.
Kansas City Mo
Allright got it I will try later tonight, its family supper time!
