DSD+ Fast Lane setup questions
vince48
Central Valley, CA.
Question, if I'm using FMP both CC and VC .bat files do I need to also run CC and VC .bat files? the "trunking" tesx file says:
all batch files are designed to be run from your usual DSD+ folder;
either start four console windows in that folder, or if using desktop shortcuts
to run the batch files, specify that those shortcuts start in your usual DSD+ folder
I'm confused. When I edit my FMP CC file with a control channel frequency, I see no scrolling or control channel activity from DSD.
vince48
thegriff
Hillsboro, OR
Yes vince48 you do need to run all four. The two FMP bat files merely tune the dongles, the CC and VC bat files do the decoding.
Forts
Ontario, Canada
Can someone confirm whether or not I'll need 2 dongles to do trunking?
From the trunking.txt that came with DSD+ 1.080:
The control signal source can be any NFM receiver whose flat audio is piped to
DSD+ via a mic or line in input, or an SDR device (DVB-T dongle, Airspy, etc.)
whose demodulated audio is piped to DSD+ via Virtual Audio Cable or VB-Cable.
So, no... you don't need two dongles. A scanner or similar tapped radio can be used to sit on the control channel.
vince48
Central Valley, CA.
can some kind sole send or post a sample of their FMPCC.bat and CC.bat file. I'm still not getting any control channel activity. i'm using the same port 20001 in both but no activity, the control frequency is good and strong. thanks in advance.
vince48
vince48
Central Valley, CA.
vince48
Sorry guys, I figured it out. was running only FMP-CC.bat and CC.bat but not DSD.exe Sorry to be a PIA.
vince48
D
DaveNF2G
Guest
How did you manage to guess this information? FMP-CC.bat is not mentioned at all in the documentation.
To the DSD+ author(s) - Please please please add a list of startup steps in sequence to run this program correctly. You know, like
1 Execute CC.bat
2 Execute whatever comes next
3 etc.
slicerwizard
Toronto, Ontario
From the Trunking.txt file:
Trunking
the CC source receiver can be a DVB-T dongle or a discriminator-tapped radio
if using a DVB-T dongle, run the FMP-CC batch file, tune to an active CC,
then adjust RF bandwidth filtering, RF gain, etc. as required
pressing '?' will list all active keys in FMP's console window
run the CC batch file to start the CC-decoding copy of DSD+
if you have your CC audio routed correctly, DSD+ should start decoding and scrolling
the VC source receiver *must* be a DVB-T dongle
run the FMP-VC batch file; FMP should automatically enter trunk-following mode
RF gain can be adjusted as required at any time
you should see FMP tuning to voice channels as comms show up on the CC
run the VC batch file to start the VC-decoding copy of DSD+
if you have your VC audio routed correctly, DSD+ should decode voice
traffic as comms show up on the CC
1, 2, 3, 4 ...
DSDPlus
CC.bat runs DSD+. That is its only job. Is DSD+ terminating? If it is, what does it say? What is in the log file?
vince48
Central Valley, CA.
Mr. DSDPlus
i run FMP-CC.bat, then CC.bat and nothing happens. I do not see and channel activity, event log and source audio windows open.
D
DaveNF2G
Guest
OMG. I missed that line completely. Sheesh. (Embarrassed emoticon goes here.)
My text search didn't find it because it is not written as FMP-CC.BAT, but my eyeball search should have found it anyway.
DSDPlus
Mr. DSDPlus
Please post an exact copy of the CC.bat file that you are using.
vince48
Central Valley, CA.
Mr. DSDPlus
i have not amended the CC.bat file, but here it is
DSDPlus -rc -i20001 -v3 -wsl400.2 -wss100.200 -wel0.1 -wcl0.445 -wes400.520 >>CC.log
DSDPlus
Use Notepad to open the CC.log file. What is at the end of the file? Copy the text from the last run into your reply. Everything from the last occurrence of:
DSD+ 1.090pt
Program role is control/rest channel decoder
to the end of the file. Should not be more than about 20 lines.
vince48
Central Valley, CA.
DSD+ 1.080t
Source audio waveform window origin set to (400,2)
Source audio waveform window dimensions set to 100x200
Event log window origin set to (0,1)
Channel window origin set to (0,445)
Event log window dimensions set to 400x520
Appending synthesized audio to file 'CC-DSDPlus.wav'
0 frequency records loaded
1951 radio records loaded
329 group records loaded
39 site records loaded
4 network records loaded
audio input device #1 = 'Line In (Realtek High Definitio'
audio input device #2 = 'CABLE-A Output (VB-Audio Cable '
audio input device #3 = 'CABLE-B Output (VB-Audio Cable '
audio output device #1 = 'Realtek Digital Output (Realtek'
audio output device #2 = 'Speakers (VB-Audio Cable B)'
audio output device #3 = 'Speakers (VB-Audio Cable A)'
audio input device #3 (CABLE-B Output (VB-Audio Cable ) initialized
audio output device #1 (Realtek Digital Output (Realtek) initialized
D-STAR decoding enabled
NXDN4800 decoding enabled
NXDN9600 decoding enabled
DMR/MotoTRBO decoding enabled
P25 Phase 1 decoding enabled
X2-TDMA decoding enabled
ProVoice decoding enabled
Sync:+DMR
+DMR CACH ERR slot1 BS DATA DCC=4 CSBK ERR11 Con+ NL = 13 21 14 16 18
+DMR slot2 BS DATA DCC=4 Idle ERR2
+DMR slot1 BS DATA ERR1 DCC=4 CSBK Con+ NL = 13 21 14 16 18
CACH Sig ERR1
+DMR slot1 BS DATA DCC=4 CSBK ERR1 Con+ NL = 13 21 14 16 18
+DMR slot1 BS DATA DCC=4 CSBK Con+ NL = 13 21 14 16 18
Network=268 Site=22
+DMR slot2 BS DATA DCC=4 Idle ERR1
+DMR slot1 BS DATA ERR2 DCC=4 CSBK Con+ NL = 13 21 14 16 18
+DMR slot2 BS DATA ERR1 DCC=4 Idle
+DMR slot1 BS DATA ERR1 DCC=4 CSBK ERR3 Con+ NL = 13 21 14 16 18
Network=268 Site=22
+DMR slot2 BS DATA DCC=4 Idle ERR3
+DMR slot1 BS DATA ERR2 DCC=4 CSBK ERR1 Con+ NL = 13 21 14 16 18
+DMR slot1 BS DATA DCC=4 CSBK ERR2 Con+ NL = 13 21 14 16 18
Network=268 Site=22
+DMR slot1 BS DATA DCC=4 CSBK ERR3 Con+ NL = 13 21 14 16 18
Network=268 Site=22
+DMR slot1 BS DATA ERR3 DCC=4 CSBK Con+ NL = 13 21 14 16 18
Network=268 Site=22
Network=268 Site=22
+DMR slot2 BS DATA ERR1 DCC=4 Idle ERR4
+DMR slot1 BS DATA ERR2 DCC=4 CSBK ERR2 Con+ NL = 13 21 14 16 18
CACH Sig ERR1
+DMR slot2 BS DATA DCC=4 Idle ERR4
+DMR slot1 BS DATA ERR1 DCC=4 CSBK ERR2 ECC FAIL
+DMR slot2 BS DATA ERR1 DCC=4 Idle ERR3
+DMR slot1 BS DATA ERR3 DCC=4 CSBK ERR5 ECC FAIL
CACH Sig ERR1
Network=268 Site=22
Network=268 Site=22
+DMR slot2 BS DATA ERR1 DCC=4 Idle ERR2
Network=268 Site=22
Network=268 Site=22
+DMR slot2 BS DATA DCC=4 Idle ERR5
+DMR slot1 BS DATA ERR1 DCC=4 CSBK ERR5 Con+ NL = 13 21 14 16 18
CACH Sig ERR1
+DMR slot1 BS DATA ERR3 DCC=4 CSBK ERR2 Con+ NL = 13 21 14 16 18
Network=268 Site=22
+DMR slot1 BS DATA ERR1 DCC=4 CSBK ERR1 ECC FAIL
Network=268 Site=22
Network=268 Site=22
Network=268 Site=22
Sync:+DMR
CACH Sig ERR2
+DMR CACH ERR slot1 BS DATA DCC=4 Idle ERR9
+DMR slot1 BS DATA ERR1 DCC=4 CSBK ERR1 Con+ NL = 13 21 14 16 18
CACH Sig ERR1
Network=268 Site=22
+DMR slot2 BS DATA ERR1 DCC=4 Idle ERR1
Network=268 Site=22
Network=268 Site=22
Network=268 Site=22
+DMR slot2 BS DATA ERR3 DCC=4 Idle ERR7
+DMR CACH ERR slot1 BS DATA ERR2 DCC=4 CSBK ERR4 Con+ NL = 13 21 14 16 18
+DMR slot1 BS DATA ERR1 DCC=4 CSBK ERR2 Con+ NL = 13 21 14 16 18
CACH Sig ERR1
DSDPlus
DSD+ 1.080t
That is from the very *end* of CC.log?
It is from a DSD+ 1.080 run, not 1.090.
