DSD+ Fast Lane setup questions
DSDPlus
Delete CC.log and then run CC.bat
That way, the log file will only contain data from the one run.
W4KRR
Coconut Creek
On occasion, I get this message on startup:
Can't open configuration file
Error processing config file (FMP.cfg)
Normally, the fix is to close all windows and restart the program.
The file isn't set to read only; even so, I don't think this file gets written to. Don't know if's an issue with my system or not.
vince48
Central Valley, CA.
DSD+ 1.090pt
Program role is control/rest channel decoder
Source audio waveform window origin set to (400,2)
Source audio waveform window dimensions set to 100x200
Event log window origin set to (0,1)
Channel window origin set to (0,445)
Event log window dimensions set to 400x520
Appending synthesized audio to file 'CC-DSDPlus.wav'
17 frequency records loaded
DSDPlus
Are two copies of FMP trying to read the configuration file at the same time? It should not be a problem, but nothing else comes to mind.
FMP does not write to the configuration file.
DSDPlus
DSD+ 1.090pt
This suggests that DSD+ died while loading the DSDPlus.radios file.
What happens if you rename that file?
vince48
Central Valley, CA.
Mr. DSDPlus
renaming DSDPlus.radios to DSDPlus1.radios, opens CC activity window and the associated DSD windows. what happened? is DSDPlus.radios file bad or corrupt?
DSDPlus
It must be. Would you please email a copy of it to us? It will show us where DSD+ is breaking.
DSDPlus
We will be sending out updates that fix the file corruption bug. Should be today or tomorrow.
n2pqq
Is there someone who could write a step by step
Tutorial showing how to get trunking working.
Or maybe a video .
wildbillx
Cape May, NJ
Hello all, so I have watched the video "a couple times" and have been messing with the settings to get the FMP to work on a Nxdn48 system. I can see the cc and see it is tracking but when I go to the VC I hear nothing and see nothing in those windows. So that makes me think I am not setting up input and output correct. If anyone has a minute to help let me know what info you need. I will be playing around with it. Thanks.
Nevermind, just starting hearing voice. LOL
W4KRR
Coconut Creek
On occasion, I have observed that the voice channel following becomes "stuck" on a single frequency. In this condition, there is a beep from the speakers every 2 to 3 seconds. If a conversation goes to the stuck frequency, you hear the audio as you normally would, but it won't follow the conversation; you won't hear anything until the stuck frequency becomes active again. The FMP VC window doesn't "grey out" between voice conversations as it normally does; it stays active, but with a flat green line when no voice is present.
I can sometimes fix this by closing VC.bat and FMP-VC.bat and re-opening them, or just closing everything and restarting.
This is a NXDN 48 trunked system.
vince48
Central Valley, CA.
Greetings
I hope someone can help or has experienced the same issue I have. I;m having issues with FMP VC. I'm using a dongle as the tuner, when there is a voice transmission, i see the traffic file
Traffic: Con+_319-3_0004_0.00000_GC_15000_229944.traffic
but the FMP VC channel activity window is blank. The TCP port is 20002. why is this? Any help out there.
vince48
slicerwizard
Toronto, Ontario
You're monitoring a DMR Con+ system, network ID is 319, current site is site 3, a group call is active on channel 4 (second RF channel, second timeslot), but your DSDPlus.frequencies file doesn't have a line defining what radio frequency is used by Con+ system 319, site 3, channel 4 (or channel 3 - they they use the same physical RF channel)
vince48
Central Valley, CA.
slicerwizard,
yes it does. my DSDPlus.frequencies file
Con+, 319, 1, 1, 0.0, 489.63750, 0
Con+, 319, 1, 2, 0.0, 490.36250, 0
Con+, 319, 1, 3, 0.0, 483.98750, 0
Con+, 319, 2, 1, 456.07500, 451.07500, 0
Con+, 319, 2, 2, 467.45000, 462.45000, 0
Con+, 319, 2, 7, 456.16250, 451.16250, 0
Con+, 319, 3, 1, 0.0, 489.06250, 0
Con+, 319, 3, 2, 488.61250, 483.61250, 0
Con+, 319, 4, 1, 0.0, 490.42500, 0
Con+, 319, 4, 2, 457.62500, 452.62500, 0
Con+, 319, 4, 3, 489.41250, 484.41250, 0
Con+, 319, 5, 1, 0.0, 490.71250, 0
Con+, 319, 5, 2, 489.26250, 484.26250, 0
Con+, 319, 6, 1, 457.12500, 452.12500, 0
Con+, 319, 6, 2, 467.37500, 462.37500, 0
the protocol says use the TX frequencies frist, then the receiving frequency.
vince48
cg
Connecticut
From the system point of view the TX is the lower and the RX is the higher one. Swap the frequencies.
chris
