With my lists, I have the repeater output listed first. Yours appear to have the inputs listed first.
Those two lines reference the same RF channel. DSD+ DMR channels 1 and 2 are timeslots 1 and 2 on the first RF channel.Con+, 319, 3, 1, 0.0, 489.06250, 0
Con+, 319, 3, 2, 488.61250, 483.61250, 0
From DSDPlus.txt:
DSDPlus.frequencies
DSD+ uses this file to display frequency information when DSD+ is monitoring
a rest channel or control channel. The frequency records will also be
used to control channel steering for trunked voice following.
Note:
DSD+ uses two channel numbers for each DMR RF channel:
Channel #1 = first RF channel, timeslot 1
Channel #2 = first RF channel, timeslot 2
Channel #3 = second RF channel, timeslot 1
Channel #4 = second RF channel, timeslot 2
Channel #5 = third RF channel, timeslot 1
Channel #6 = third RF channel, timeslot 2
For all DMR systems (DMR, Cap+, Con+, TIII), only one channel record has
to be added to the DSDPlus.frequencies file for each RF channel.
You can use the channel number that corresponds to timeslot 1 or 2 and
DSD+ will use the same frequency information for the other timeslot.
You have two entries for the first RF channel and no entry for the second RF channel (so change Con+, 319, 3, 2 to Con+, 319, 3, 3)
DSD+ expects to see the system TX frequency first, then the optional system RX frequency. Your list has the higher numbers (subscriber equipment TX frequencies) first.Well Sir, the protocol says TXfreq first, the offset's is +5Mhz and +3Mhz for the receiving frequencies. Am I wrong or are the DSD protocol wrong?
I don't think any of this has changed since the DSDPlus.frequencies file was introduced. The order was always site TX freq, site RX freq and DSD+ always used separate channel numbers for each DMR slot.this is becoming a moving target. Too many moving parts.
When you write output, receiving and transmit, you have to be clear on whose reference point you are using - the system repeaters? the subscriber units? DSD+?the output (receiving frequency) frequency is 484.xxxx, wouldn't the transmit frequency be 5 Mhz higher at 489.xxxx?
In North America, UHF bands typically use +3 or +5 MHz as you noted; that means the system RX frequencies are 3 or 5 MHz higher than the matching system TX frequency. So pairs like TX=451.xxxx, RX=456.xxxx are very common. That's system TX is 451, subscriber TX is 456...please do not misconstrue me, but the DSD protocol ask for the transmit frequency frist (higher number)
You can give an example of how to DSD + frequency file to do a scan of a group of frequencies?
Grazie Maurizio
; DSD+ frequency file
; you can edit this file while DSD+ is running
; line format:
; protocol, networkID, siteNumber, OTAchannelNumber, TXfrequency, RXfrequency, sortOrder
; for TIII, siteNumber format = area.site
; use site number = 0 for network-wide definition
; use 0.0 for unknown frequencies
; use sort order = 0 to sort by OTA channel number
; protocols:
; D-Star
; IDAS
; NEXEDGE48
; NEXEDGE96
; dPMR
; DMR
; Cap+
; Con+
; TIII
; P25
; ProVoice
; KELLY TOWER SITE 2
NEXEDGE96, 25, 2, 255, 453.17500, 453.17500, 0
NEXEDGE96, 25, 2, 274, 453.41250, 453.41250, 0
NEXEDGE96, 25, 2, 287, 453.57500, 453.57500, 0
NEXEDGE96, 25, 2, 297, 453.70000, 453.70000, 0
NEXEDGE96, 25, 2, 308, 453.83750, 453.83750, 0
;Channel Map for Site 1 - Hopkinsville
NEXEDGE96, 25, 1, 213, 452.6500, 452.6500, 0
NEXEDGE96, 25, 1, 257, 453.2000, 453.2000, 0
NEXEDGE96, 25, 1, 283, 453.5250, 453.5250, 0
NEXEDGE96, 25, 1, 295, 453.6750, 453.6750, 0
NEXEDGE96, 25, 1, 311, 453.8750, 453.8750, 0
NEXEDGE96, 25, 1, 405, 460.0500, 460.0500, 0
NEXEDGE96, 25, 1, 416, 460.1875, 460.1875, 0
NEXEDGE96, 25, 1, 438, 460.4625, 460.4625, 0
;Channel Map for Site 3 - Oak Grove
NEXEDGE96, 25, 3, 259, 453.2250, 453.2250, 0
NEXEDGE96, 25, 3, 269, 453.3500, 453.3500, 0
NEXEDGE96, 25, 3, 281, 453.5000, 453.5000, 0
NEXEDGE96, 25, 3, 302, 453.7625, 453.7625, 0
NEXEDGE96, 25, 3, 411, 460.1250, 460.1250, 0
;Channel Map for Todd Co Elkton Tower
NEXEDGE48, 161, 1, 1, 453.18125, 453.18125, 0
NEXEDGE48, 161, 1, 2, 453.19375, 453.19375, 0
NEXEDGE48, 161, 1, 3, 453.27500, 453.27500, 0
NEXEDGE48, 161, 1, 4, 453.66250, 453.66250, 0
NEXEDGE48, 161, 1, 5, 460.10000, 460.10000, 0
The DSDPlus.frequencies file is for NEXEDGE48/96, DMR Con+ and DMR TIII trunking systems. It tells DSD+ what the frequencies are for each system and site. DSD+ uses this information to display trunking system activity with matching frequencies in the channel activity window. DSD+ 1.080+ uses this information to follow voice calls. It is not used for conventional scanning.You can give an example of how to DSD + frequency file to do a scan of a group of frequencies?
