I've been monitoring a system which I think is mainly Conventional DRM and I would like to have your experienced input on this. I've devised a kind of recording system; recording all DMR activities on the specific channel 24/7 all around. Using SDR# with AUX VFO plugin, it starts recording in consecutive files when activity happens. At the end of the cycle, I stitch all the files into a big one, and lastly I put it through DSD+. A simple but effective system.
Now, I asked before in this forum about this specific repeater, but at the time I had made a mistake and I was wrongly decoding two repeaters in a sigle frequency. Now those mistakes are gone, and I have strong, clear signal.
99% of this repeater activity is some kind of data exchange. There are three main active transmitting users; RID 8, 105 and 354. Also there is another passive user; RID 1 which is (in my opinion) some kind of USB device on the system (because of it's IP decoding to 13.x.x.x). There is only one TG which is 1001. Now, DSD+ FL decodes clearly the rare voice traffic, but gives no sign what the data traffic is. @slicerwizard said it is ARS (because of ARS) and I am tempted to say the same, but, I have reason to believe this is no ARS because the data burst happen every minute or three from the tree active users, directed to RID 1, which only listens and never transmit. At the end of this post I will post links to the waw recording and logs file for one cycle recorded a couple of days ago, but in the meantime, decoded data bursts looks like this:
The full decoded logs on txt format will be at the end of the post.
As I said, I have reasons to believe this is no ARS, but some kind of status messaging or even some kind of LRRP (maybe) data.
I would love your help in resolving this "mystery" if possible. I am an extremely person and would love to see the light at the end of this, lol.
Thanks you all in advance for your time.
Full DSD+ Logs: https://drive.google.com/open?id=0B69B8tKwFdSvWkhib2FvVWFseVk
Full WAW raw recording: https://drive.google.com/open?id=0B69B8tKwFdSvZXFKVHRUbTVZaDg
Full WAW raw recording zipped in a RAR file: https://drive.google.com/open?id=0B69B8tKwFdSvZmRtQlF2RHZOX0E
Thanks again guys!
Code:
+DMR slot1 BS DATA DCC=1 Idle
+DMR slot2 BS DATA DCC=1 Idle
+DMR slot1 BS DATA DCC=1 CSBK Preamble 0013 Tgt=1 Src=354
Null SLCO
+DMR slot1 BS DATA DCC=1 CSBK Preamble 0012 Tgt=1 Src=354
+DMR slot1 BS DATA DCC=1 CSBK Preamble 0011 Tgt=1 Src=354
Activity update: Slot1=Indiv CSBK Slot2=No Activity
+DMR slot1 BS DATA DCC=1 CSBK Preamble 0010 Tgt=1 Src=354
+DMR slot1 BS DATA DCC=1 CSBK Preamble 000F Tgt=1 Src=354
+DMR slot1 BS DATA DCC=1 CSBK Preamble 000E Tgt=1 Src=354
+DMR slot1 BS DATA DCC=1 CSBK Preamble 000D Tgt=1 Src=354
+DMR slot1 BS DATA DCC=1 CSBK Preamble 000C Tgt=1 Src=354
+DMR slot1 BS DATA DCC=1 CSBK Preamble 000B Tgt=1 Src=354
+DMR slot1 BS DATA DCC=1 CSBK Preamble 000A Tgt=1 Src=354
+DMR slot1 BS DATA DCC=1 CSBK Preamble 0009 Tgt=1 Src=354
+DMR slot1 BS DATA DCC=1 CSBK Preamble 0008 Tgt=1 Src=354
+DMR slot1 BS DATA DCC=1 CSBK Preamble 0007 Tgt=1 Src=354
+DMR slot1 BS DATA DCC=1 CSBK Preamble 0006 Tgt=1 Src=354
+DMR slot1 BS DATA DCC=1 CSBK Preamble 0005 Tgt=1 Src=354
+DMR slot1 BS DATA DCC=1 CSBK Preamble 0004 Tgt=1 Src=354
+DMR slot1 BS DATA DCC=1 Data Header DPF=[3:ConfData]
+DMR slot1 BS DATA DCC=1 Rate 3/4 Data 45 00 00 26 00 29 00 00 40 11 60 3C 0C 00 01 62 E..&.)..@.`<...b
+DMR slot1 BS DATA DCC=1 Rate 3/4 Data 0D 00 00 01 0F A5 0F A5 00 12 9D 8D 00 08 F0 20 ...............
+DMR slot1 BS DATA DCC=1 Rate 3/4 Data 03 33 35 34 00 00 .354..
+DMR slot1 BS DATA DCC=1 TLC Data Tgt=1 Src=354 61
Null SLCO
Null SLCO
+DMR slot1 BS DATA DCC=1 CSBK Preamble 0004 Tgt=1 Src=105
Null SLCO
+DMR slot1 BS DATA DCC=1 Rate 3/4 Data 45 00 00 26 02 9E 00 00 40 11 5E C0 0C 00 00 69 E..&....@.^....i
+DMR slot1 BS DATA DCC=1 Rate 3/4 Data 0D 00 00 01 0F A5 0F A5 00 12 A3 87 00 08 F0 20 ...............
+DMR slot1 BS DATA DCC=1 Rate 3/4 Data 03 31 30 35 00 00 .105..
+DMR slot1 BS DATA DCC=1 TLC Data Tgt=1 Src=105 66
Thanks again guys!
