DSDPlus DSD+ Fastlane NXDN Control Channel
kirkco
Erda, Utah
Need a little clarification please. When I select a frequency for a NXDN system in the FMP24 window (example 451.0250), and then the channel activity window shows a channel (example 83 as the CC), is 83 the Control Channel for the frequency I am currently on (see image) or could 83 actually be another frequency? I'm confused because I see channel 83 assigned to several frequencies in the same system.
u2brent
OAMPT
KRWDPAXKRS1
The answer is found on these pages..
The same frequency 451.025 has the same CH ID 83 across the system in this case, not sure what different frequencies your referring too.. It's only listed as a CC for Lark1.
mattwillson
83 is the channel ID. 452.2 is the control channel for the south mountain site.
bravo14
Polk County FL
You'll need to go to freqs in dsdplus note pad and make a list for the nexedge96 and put in the freqs should be like this
NEXEDGE96, 64, 5, 83, 451.0250, 0
NEXEDGE96, 64, 5, 113, 451.4000, 0
NEXEDGE96, 64, 5, 141, 451.7500, 0
NEXEDGE96, 64, 5, 177, 452.2000, 0
u2brent
OAMPT
KRWDPAXKRS1
Technically you could add it as such.. I'd add all the Frequencies/Channels from all the sites to one list.
NEXEDGE96, 64, 0, 83, 451.0250, 0
NEXEDGE96, 64, 0, 113, 451.4000, 0
NEXEDGE96, 64, 0, 141, 451.7500, 0
NEXEDGE96, 64, 0, 177, 452.2000, 0
Since the same Channels are used across all sites in the same system..
The 0 in the site value field tells DSD+ that the same channel numbers apply to any site received.
CH IDFrequency
83451.025
113451.400
115451.425
131451.625
135451.675c
141451.750
177452.200
495461.175
503461.275
527461.575
555461.925
558461.9625
562462.0125
663463.275c
670463.3625
682463.5125
691463.625
692463.6375
707463.825
716463.9375
721464.000
757464.450
784464.7875
797464.950
Note: The RAN that is decoded by DSD+ is generally also the Site number..
shajoe44
North Augusta, SC
If you do not know the frequencies associated with the Channel ID, can you just put "0" in the Channel ID column and just use the frequencies on the license? There is a FleetTalk system here in GA that looks like has random Channel ID's assigned to frequencies. I have the CC frequency and Channel ID for that frequency on a few of the sites I can monitor.
kirkco
Erda, Utah
I think I've got it now and learned a couple "tricks" along the way thanks to your help. I suppose it was the "CC" indicator that put me off thought. I've set up my list as suggested and will monitor during the week (not much business activity this weekend).
Thank-you all!!
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Thank-you all!!
They key thing is that the control channel can change. Right now it is 451.025.
CHID 83 <--> 451.025 ; on the system/site you are monitoring, 451.025 will always be CHID 83.
But CHID (or 451.025) will not always be the control channel.
On most trunked systems, there is more than one control channel. That way if something fails on the 451.025 transmitter, there is another frequency/transmitter to take its place automatically, and the site controller will make sure that happens. You might not know what one of the alternate control channels is right now (and it really doesn't matter since it would not be active as a control channel right now), but there very is likely one. And in fact, depending upon the system, the control channel may rotate amongst all frequencies on the sites - daily, weekly, etc.
So one day a channel that was delivering voice may be the CC and a channel that was the CC may be delivering voice.
Mike
kirkco
Erda, Utah
Mike
That makes a lot of sense to me now. I started to keep a log (Excel sheet) to try to map my "finds" using DSD+. I would then log my "discoveries" (ex, the cc) and the next time I looked at the same data-set, the channel is not even making a peep. Drove me crazy...started blaming my antenna, weather, aliens...The pieces are finally starting to fall into place for me. Thank-you for your detailed explanation!
mtindor
FMP24 PRO USER
You're welcome. I'm glad to help you out. I probably should say one more thing, even though it'll just add confusion.
When I said CHID 83 will always be 451.025 on that particular site of that system, that's not quite a guarantee. The system programmer can manually assign any channel ID to any frequency they want and really cause some confusion. But, with that said, after the system and/or site is already set up, they are very unlikely to change things like that.
Take it easy
Mike
