I used 2 RTL-SDR's for trunking. I am also enclosing what is in my DSD Plus folder in a image.
Ok it looks like you have some, but not all. Mainly missing the CC.bat and VC.bat. Some settings are particular to a given setup. Do you have dongles that require you to add in a PPM adjustment for drift? Or are they dongles with low-ppm TCXOs? That'll matter, since on dongles where you have to compensate for drift one must add an additional parameter to the lines in FMP24 to adjust for drift properly.
What is your DSDPlus output audio line? If you run "dsdplus" all by iself, as soon as it starts up it lists the various audio sources and destinations (inputs and outputs). Can you tell me which audio output is your speakers?
For instance, when I start DSDPlus all by itself, in the command window it shows my audio sources / destinations (yours will be different). My audio output device for the speakers is "audio output device #1". What is yours?
audio input device #1 = 'Internal Mic (IDT High Definiti'
audio input device #2 = 'Line 1 (Virtual Audio Cable)'
audio input device #3 = 'Line 3 (Virtual Audio Cable)'
audio input device #4 = 'Line 4 (Virtual Audio Cable)'
audio input device #5 = 'Jack Mic (IDT High Definition A'
audio input device #6 = 'Line 2 (Virtual Audio Cable)'
audio output device #1 = 'Speakers / Headphones (IDT High'
audio output device #2 = 'Line 4 (Virtual Audio Cable)'
audio output device #3 = 'Communications Headphones (IDT '
audio output device #4 = 'Line 3 (Virtual Audio Cable)'
audio output device #5 = 'Line 1 (Virtual Audio Cable)'
audio output device #6 = 'Line 2 (Virtual Audio Cable)'
audio input device #1 (Internal Mic (IDT High Definiti) initialized
audio output device #1 (Speakers / Headphones (IDT High) initialized
