thewraith2008
- Joined
- Nov 22, 2016
- Messages
- 1,841
Note that you may need to update
base dll files in this version to stop the missing dll or wrong checksum messages.
Code:
Change Log
DSD+ 2.268
Fixed P25 channel 0-0 handling.
Significantly improved Fusion decoding.
Added dPMR link control display and AMBE+2 voice synthesis. dPMR decoding has to be enabled.
Modified site loader window operation:
Controlled by mouse / pointer device only; no keyboard inputs.
Left or right click on an entry to highlight it.
Left click highlighted entry to tune to it and close site loader window.
Right click highlighted entry to tune to it and leave site loader window open.
Added direct connection mode:
Connects DSD+ to FMPA/FMPP/FMP24 without using network.
Use -i<linkID> on DSD+ command line for direct connection.
Use -iT<addr:port> on DSD+ command line for TCP link to remote PC.
Added integrity check for lame_enc.dll file; correct file is in DLL bundle at dsdplus.com
Added menu entry to download newest base files. Provides access to up to date copies of
all DSD+ companion programs, configuration files, batch files, data files and required DLLs.
FMP24 2.70
Use -o<linkID> on FMPA/FMPP/FMP24 command line for direct connection.
Use -oT<addr:port> on FMPA/FMPP/FMP24 command line for TCP link to remote PC.
Added I/Q data loss diagnostic mode; Press L key to start/stop data loss test.
Added DLL files integrity checks. Required DLLs must be present in FMP24's working folder.
Missing DLLs can be acquired via the DSD+ Download Newest Base Files menu entry.
FMPA 2.37
Added direct connection mode; see FMP24 notes above.
Added DLL files integrity checks; see FMP24 notes above.
FMPP 1.15
Fixed IF gain set bug.
Updated to SDRPlay API version 3.07
sdrplay_api.dll
DLL for SDRPlay API version 3.07; this file should be in FMPP's working folder.
