DSD+ Fastlane - Updated v2.390
thewraith2008
Code:
Change Log
DSD+ 2.390
    More changes made to limited encrypted voice following
    and to tracking and display of encryption algorithms and KID values.
    More changes to neighbor reporting logic.
    Blocked writing of TIII reserved IDs (PSTNI, PABXI, etc.) to DSDPlus.radios file.
    Better handling of DSDPlus.frequencies file data where multiple sites in a network
    use the same radio frequencies.
Reconrider
Inside the Galaxy
Radio Galaxy
Anyone else notice the version before this Gigi nb a lot of audio wave blocks being discarded? Does this fix it?
u2brent
OAMPT
KRWDPAXKRS1
This seems to be another borked fix to me. Back to 2.368, Again. :rolleyes:
Tried enabling Limited Enc Following the event window indicates the change selected has occurred, Yet upon return visits to the menu after this change it once again indicates No Following is selected. Which is it? :geek:
Sorry.
[Edit to add: this is occuring using separate DSD CC/VC instances.]
deathtone
This update fixed the constant neighbor reporting problem for me.
Forts
Ontario, Canada
I've been using Limited ENC Following since I downloaded the update on the weekend. Seems to be working ok for me so far.
m1064
I'm using dsd+ 2.368, and when I checked update,
I got the following and what should I do? Thanks.
Server name: dsdplus.com
Alternate : www.dsdplus.com
Server address: 209.240.30.50
TCP receive failure
Update check failed
thewraith2008
Just try again later.
For me the webpage at www.dsdplus.com is up and running. (and the 'Check for Updates' works).
If you can access www.dsdplus.com in a web browser then you may want to look at if dsdplus.exe internet access is blocked.
hrh17
I've noticed with encrypted voice following set to full and using 2 Instances of DSDPLus for example 1 CC / 1 VC the ALgo & Key Ids are not being displayed in the Seen Groups window. However when I switch each instance over to 1R mode the Algo & key Ids populate in the seen Groups Window.
slicerwizard
Toronto, Ontario
That information isn't broadcast on control channels, so a side that only monitors the CC will never see or display algorithm names or key IDs.
ArloG
I don't care. I want fmpxx that works with my IC-R8600. Or at least a cat control module with command configuration file.
fmp8600. Or maybe fmpcat. How cool would that be?
hrh17
So then why isn't my VC seen groups displaying this information then? Besides in the call log window
m1064
Thanks for reply, I got it updated in Windows 8 but not in linux with wine and I don't know why.
BTW, would you like to tell me where I can learn dsd+'s limited encrypted p25 tutorials.
Forts
Ontario, Canada
There aren't any official tutorials. Make sure you read the notes.txt that comes with each release though. It will list new features and what they do.
ArloG
Perhaps it could be done if you donate a R8600 to the DSDPlus developers to help them figure it out...
That should not be necessary if you are familiar with cat command tables. As well as hamlib.
I believe your comment was hurried and unnecessary.
DSD+ Steve Miller version. Go on, take the money and run.
Again. Nowhere on the Fastlane page does it list supported radios. And this had led people thinking SDR radios would be supported by purchasing it. I'm not the only one. With 0 feedback or email response. Yet they suggest coming to RR for support.
LA6FRA
Stavanger. Norway
Code:
Change Log
DSD+ 2.390
It would be nice if DSD+ can log the frequency in the event file. So when I change frequency, I can find which TG and other information belongs to.
cg
Connecticut
You mean like the -E option does?
-E Add Frequency/NAC/RAN/DCC/RAS data to Event Log entries.
