DSD+ Features for Receivers Question
ArloG
Is this the site that has the most influence on the DSD+ devs? I've had a Fastlane sub that will expire in December.
I've gotten some of it working using an RSP2. I'm also using it through HDSDR with my IC-R8600. It took a short time to find the USB audio out wouldn't decode.
I was wondering is there are any plans to implement receiver control like FMPXX with CAT to allow frequency hopping for trunked transmissions over USB or TCP/IP.
It seems like that would be a cool feature seeing as more and more are getting their tickets these days and buying good radios.
Forts
Ontario, Canada
I wouldn't expect too many customizations for things like the RSP etc as they just aren't used as much as the generic RTL dongles & airspy. I'd expect maybe things like multi VFO etc would be a higher priority for them. Plus, it's hard to code for setups like you are mentioning if you don't have the hardware on hand.
