DSD+ FL Trouble Decoding Tier 3 Control Channel
ECPD279
Bay Area, CA
In one of the recent updates, DSD+ FL started exhibiting a strange behavior on Tier 3 channels.
When I settle on a channel, the site number will rapidly cycle between the correct site number (For example 1-1.1) and site 1-1 causing an inability to continuously decode the data stream. Instead it just shows a steady stream of alternating...
Current site: 1-1.1
Current site: 1-1
Current site: 1-1.1
Current site: 1-1
Current site: 1-1.1
Current site: 1-1
Current site: 1-1.1
Current site: 1-1
This was not an issue before, but just popped up maybe three or four releases ago.
The channels I monitor vary in strength from barely breaking squelch to S9+ and all show the same issue, so it is unlikely this is a signal strength issue..
dave3825
Suffolk County NY
Which release did it start on? On older release or one of the two that came out like June 1st and June 2nd?
dave3825
Suffolk County NY
Here is the notes file from 384. I know noting about tier 3 as none in my area.
Read thru the notes from 368 to 384 and see if your issue was addressed.
  • Notes.txt
ECPD279
Bay Area, CA
I'm noticing now that it only seems to happen on "S" sites. "L" and "H" sites work properly.
slicerwizard
Toronto, Ontario
EXACTLY what kind of TIII channel? Got any raw source audio recordings?
