DSDPlus DSD+ FL, working flawlessly so far, first time seeing this kind of MotoTRBO DMR signal, what is it?
Hi!
I have been playing with DSD+ FL and radio in general for some time, using my airspy or rtl dongle, very fun!! Listened to local construction workers and some hams experimenting, and I found some repeaters just spamming nothing ("Idle"). Then I found this on 450MHz and I can't wrap my head around what it is.
Here's what I know so far:
  • My antenna is a dipole tuned to the exact frequency and I'm 100% sure that there's no interference and the signal is good and not clipping; also gain and bandwith are properly adjusted.
  • It's a DMR MotoTRBO signal, 100%. Sounds exactly like it, decodes like it.
  • I managed to retrieve some of voice data, but I can't make out anything.
Activity update: Slot1=Group Voice Slot2=No Activity
+DMR slot1 BS DATA DCC=1 TLC ECC/RAS Enc GC End TG=1 RID=11101
+DMR slot2 BS DATA DCC=1 Idle
+DMR slot1 BS DATA DCC=1 PI Header ECC/RAS Alg=RC4 KID=3 MI=EBAA4E13 Tgt=1
Activity update: Slot1=No Activity Slot2=Group Voice
+DMR slot2 BS VC6
Slot2: Enc TXI GC TG=474 RID=14100
+DMR slot1 BS DATA DCC=1 Idle
+DMR slot2 BS DATA DCC=1 TLC ECC/RAS [FLCO=0 FID=10 v8=60 id1=474 id2=14100]
00 10 60 0001DA 003714
000000000001000001100000000000000000000111011010000000000011011100010100100010010001011010110010
Sync:+DMR
+DMR CACH ERR slot1 BS DATA DCC=1 Voice Hdr ERR15 ECC FAIL
+DMR slot2 BS DATA DCC=1 PI Header ECC/RAS Alg=RC4 KID=2 MI=B898B682 Tgt=474
+DMR slot2 BS VOICE
+DMR slot2 BS DATA DCC=1 TLC ECC/RAS [FLCO=0 FID=10 v8=60 id1=474 id2=1461]
00 10 60 0001DA 0005B5
000000000001000001100000000000000000000111011010000000000000010110110101011100100100000100001111
+DMR slot2 BS DATA DCC=1 Voice Hdr ECC/RAS Enc TXI GC TG=474 RID=14100
+DMR slot2 BS DATA DCC=1 PI Header ECC/RAS Alg=RC4 KID=2 MI=5C23410E Tgt=474
+DMR slot2 BS DATA DCC=1 TLC ERR4 ECC FAIL
Sync:+DMR
Sync:+DMR
+DMR slot2 BS DATA DCC=1 Voice Hdr ECC/RAS Enc TXI GC TG=474 RID=1461
+DMR slot2 BS DATA DCC=1 PI Header ECC/RAS Alg=RC4 KID=2 MI=1EC58D16 Tgt=474
+DMR slot2 BS VC6
+DMR slot2 BS VOICE
Also recieved LRRP data which I succesfully viewed and that worked. So I'm confuesd. There's LRRP, there's data, but no voice. Why? Also, recieved some voice, but it's weird.
Null SLCO
+DMR slot2 BS DATA DCC=1 Data Header DPF=[2:UcData] Tgt=16448250 Src=129 Conf=0 SAP=[4:IP Data] Blocks=5 Pad=5 Last=0 Seq=0
+DMR slot2 BS DATA DCC=1 Data Header DPF=[7:?]
Null SLCO
+DMR slot2 BS DATA DCC=1 Data Header DPF=[13:SD-Def] Tgt=5990400 Src=882505 Conf=0 SAP=[5:ARP] Blocks=33 Format=??? PadBits=1
+DMR slot2 BS DATA DCC=1 Data Header DPF=[8:?]
Activity update: Slot1=No Activity Slot2=Indiv Data
+DMR slot2 BS DATA DCC=1 Data Header DPF=[6:?]
+DMR slot2 BS DATA DCC=1 Data Header DPF=[3:ConfData] Tgt=5241732 Src=13378382 Conf=0 SAP=[6:?] Blocks=64 Pad=13 Last=0 Seq=7 S=1 N(S)=6
How the audio sounds: Weird audio DSD
P.S. There's more information I wasn't able to include in the post from the logs, due to 15000 character limit. I hope this will be enough info.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Hi!
There is no voice because the voice is Encrypted : Alg=RC4 (RC4 encryption in use)
Mike
Mike
Hi Mike! Thank you so much for replying. Ah yes! I see now. I found this post too talking about that exact thing. DSD+ FastLane Decoding - ARS or some unknown kind of LRRP?
Oh I see! I suppose it's impossible to listen to it unless I have the key then, yes? I wonder now who's on there heh. I'm just confused how I was able to recieve some garbled audio from it.
What would you do next Mike, if you were in my shoes?
Big thanks again :) I appreciate your time.
Kazzaw
South East QLD, Australia
Nothing you can really do with it, in most places its illegal to attempt to decrypt such information.
Correct - Even with the key, DSDPlus doesn't have an option to add a key to decode the audio.
All encryption comes through as garbled audio, sometimes (settings dependent) DSDPlus lets it go through before blocking it.
Oh man! Didn't know it was illegal. I figured it was the same thing as using DSD+ to decrypt DMR haha. Thanks a lot for the reply. This really helped me understand it further. I'll leave it at that! Private broadcast :p !
Kazzaw
There is a lot of difference between decryption and decoding
Decoding is using DSD+ to decode the information sent in the radiowaves (the DMR sound you would hear if you just tuned an analog radio to the frequency)
Decryption is un-encrypting encrypted communications for the purpose of listening to the conversation.
Theres probably a better way to explain it somewhere
