DSDPlus DSD+ FMP24 Constant Idle
seagravebuff60
Short Bus Reject
Snow Bird
I am monitoring a DMR T3 trunked system, and one of the voice frequencies (452.85) in use on the system seems to have a stronger Cap+ signal riding on it as well. When im Monitoring the T3 system in "Combined CC/VC Monitor," whenever there is voice activity on the 452.85 frequency of the T3 system, FMP24 immediately goes into IDLE mode and completely stops monitoring everything. Then, it loses the CC of the T3 System as well, Forcing me to reactivate FMP24 by clicking on it and tuning to the CC manually or by using the site loader.
The T3 system is very active with activity, so I can't go more than 2-3 minutes without FMP24 going into IDLE mode.
Is there any workaround to this? I tried adjusting the gain and PPM values, but nothing.
cg
Connecticut
The DMR disambiguation is described in the Notes file for DSDPlus v2.324 (look around line 492)
I have used it with Con+ but no other flavors of DMR
seagravebuff60
Short Bus Reject
Snow Bird
That didn't seem to work.
Even tho I have all the parameters identified in the files for the T3 system, it is as if DSD+ is ignoring that for the most part, and when any voice activity from the 452.85 VC is received, DSD+ Automatically goes to the Cap+ site, and PMP24 goes IDLE.
seagravebuff60
Short Bus Reject
Snow Bird
Just reactivating this thread. I am now experiencing this behavior with a Cap+ system.
When DSD+ monitors a Cap+ system and tries to determine the Channel listing, whenever an unknown rest channel is received after about 3-4 mins, FMP24 goes into idle mode, completely stopping monitoring.
PDXh0b0
Woodland, WA
To be a little more specific, I'd download the latest base files, copy your dsdplusfastlane folder, paste it somewhere, rename it. The newly renamed folder will be you system hunting folder, open it, extract the DSDPlusBaseFiles.zip, open the DSDPlusBaseFiles folder, open the datafiles folder, copy the contents and paste into your newly renamed dsdplusfastlane folder. You don't want to manually add anything to the datafiles. Now you can create fmp24.Scanlist with the frequencies licensed to that system, run fmp24.cc & 1r.bat , let it run, checking the 1R-DSDPlus.event file with a text editor (I prefer Notepad++) you'll be searching for
Example
451.82500 is the first cap+ repeater ( Ch1 and Ch2)
I just search the text for
cap+ repeater
Myself, I didn't use the scanlist, I sat on each frequency license to the system for a length of time(after no activity (no search hits in the 1R-DSDPlus.event file) or showing it also licensed to another system(site & DCC #'s don't match), I'd move on to the next frequency.
There may be better/correct ways, it's how I've been able to set up a couple unlisted systems (not in the RR db)
