NMPhillieFan
I have installed the app and run it several times on two computers. The results are the same, it runs, but there is no audio playback. I've tried using just the exe from the command prompt as well as the batch file.
I have confirmed my default input/output in windows (even disabled everything else). When using Unitrunker, I get an all green connection, so its a good disc tap (line in). I am trying to listen to a Provoice (not encrypted) system. Any other suggestions? I must be missing something...
If its of any help, this is all I get when I run the exe within the command prompt:
Digital Speech Decoder 1.4.1
mbelib version 1.2.3
Audio In/Out Device: /dev/dsp
