DSD Frequencies File
rkillins
Can anyone see any problem with my DSD frequencies file?
I am unable to get DSD+ to recognize channel 131 of the NexEdge system, or any of the frequencies of the Con+ system.
Code:
;   use sort order = 0 to sort by OTA channel number
; protocols:
;  D-Star
;  IDAS
;  NEXEDGE48
;  NEXEDGE96
;  dPMR
;  DMR
;  Cap+
;  Con+
;  TIII
;  P25
;  ProVoice
NEXEDGE48, 202, 16, 101, 420.05625, 420.05625,0
NEXEDGE48, 202, 16, 105, 420.45625, 420.45625,0
NEXEDGE48, 202, 16, 25, 420.83125, 420.83125,0
NEXEDGE48, 202, 16, 28, 420.93125, 420.93125,0
NEXEDGE48, 202, 16, 131, 420.25000, 420.25000 ,0
Con+, 202, 8, 01, 451.5750, 451.5750,0
Con+, 202, 8, 02, 452.4250, 452.4250,0
Con+, 202, 8, 03, 454.0750, 454.0750,0
D
DaveNF2G
Guest
1) Have you tried putting the NEXEDGE frequencies into channel number order?
2) Do both systems actually use the SID of 202? Seems like an odd coincidence.
slicerwizard
Toronto, Ontario
; DSD+ frequency file
; line format:
; protocol, network ID, site number, OTA channel number, TX frequency, RX frequency, sort order
Line format specification has a space after all commas.
Per the docs, DMR channel numbers should be odd (1, 3, 5), not 1, 2, 3. And those pesky spaces...
LimaZulu
channel 131
About CH 131 - where your last comma is, you have space BEFORE the comma and not after it. Don't know if this is the case but the right syntax should be with space AFTER the comma
