DSD+ help
bailly2
suburban hell
connected my nooelec sdr to computer, installed driver with zadig,,,added some frequencies to dsdplus frequencies file,,started dsdplus command line with -i1 argument,,,source audio is moving but no activity in other windows, added a control channel frequency and a p25 conventional frequency. thanks
slicerwizard
Toronto, Ontario
Don't think you need to be adding anything to the .frequencies file unless you're running a full blown trunk tracking setup.
What SDR software are you using and what do you want to listen to?
n9mxq
Belvidere IL
Also, if there is an option to have the audio unfiltered, make sure it is. With SDRSharp it's in the Audio block. DSD+ expects raw audio.
bailly2
suburban hell
im just using dsd, tried using sdr sharp but it crashes every day. ...what do i need to enter into dsd+ to get it to listen to a specific frequency? thanks
M105
tried fmp, installed the dll it needs, ran it and it gives me a fatal error
Well, all I can tell you is that there are thousands of copies of it running out here. Read ALL the documentation that came with your DSD+ download. It does work.
