Are there any radio systems in the niagara region of ont. that are using say provoice, mototrbo? Any close to buffalo? Just wondering what I can try this software on. Thanks for the time.
you can still listen to sarnia fire as well but it is a hit or miss since the repeater is analog and you will only get the tac comms not dispatchI'm going to say that there is now MOTOTRBO in the Immediate Niagara area, and not immediately across the border. I may be wrong, but I'm pretty sure.
Sarnia has MOTORBO.....you should go down there and try the program out. There is nothing to listen to in Sarnia except EMS, and whatever can be picked up across the boarder.
When I was living in Sarnia I was never able to pick up anything from Sarnia Fire. It was hit or miss on the county depts though.you can still listen to sarnia fire as well but it is a hit or miss since the repeater is analog and you will only get the tac comms not dispatch
I was only thinking about emergency services, and completely forgot that all sorts of companies use radios. I would imagine you're correct in saying that someone must have TRBO in and around the Falls area.I can almost guarantee there will be TRBO somewhere around the falls.
ah i think sarnia fire has to have a truck in the area with a repeater turned on i live near stations 2 and 4 and i hear them doing test on it all the timeWhen I was living in Sarnia I was never able to pick up anything from Sarnia Fire. It was hit or miss on the county depts though.
No.... not exactly. The system is digital WITH an analog VR. So TAC 1, TAC 2, TAC 3 (Dispatch) and TAC 5 are all digital, all MotoTRBO. But what they can do is switch on an analog repeater at a scene if they are having problems with the digital comms. So the portables back to the trucks would be analog, then the analog is basically patched back into the digital system. Make sense?This is why I was confused a couple years ago when I was asking about Sarnia Fire. They use TRBO to dispatch, but the Tac channels, where you think they would want privacy, and encryption, they are using analog. Someone doesn't have their head screwed in correctly.
Just read this in the NY forum, you could try and help this guy out.Are there any radio systems in the niagara region of ont. that are using say provoice, mototrbo? Any close to buffalo? Just wondering what I can try this software on. Thanks for the time.
